Question about Craftsman Garden
My craftsman lawn mower, Briggs and Stratton engine, hydraulic locks with oil after it sets overnight. finnally it quits smoking till I let it set overnight. Must have a lube system for engine
  • Craftsman Master
  • 1,169 Answers
Most like over fill with oil or have a carburetor that has fuel into the crankcase creating the same problem.
Posted on Apr 17, 2015
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
  • 407 Answers
SOURCE: unable to locate oil drain
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
Posted on May 30, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs and stratton 15.5 horse power over head valve
could be to much oil in engine are bad rings in engine or bad valve seals one of those three i would go with bad valve seals
May 14, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Briggs Stratton 625 series 190cc lawn mower: this has been tipped right over and now there seems to be oil in everything and it won't go, what can we do?
If the engine has been tipped oil will come through the engine breather and soak the paper filter, remove the filter, remove the spark plug and clean/replace, with the plug out crank the engine a few times to to evacuate any oil in the cylinder, replace the plug and try again ( with the filter still removed ) when it finally starts it will smoke quite heavily so do this out side and on a non grass surface ( oil sprayed from the muffler will kill the grass) it will smoke for some time until all the excess oil has gone, check the oil level in the engine and top up if required.
Feb 18, 2012 | Craftsman Garden
My daughter added oil then proceeded to mow the lawn. mower started smoking then quit. When I got home from work I was able to start the engine one time and it smoked a lot. I turned it off and have not...
With the engine cold, check the oil level. Oil level is quite important especially in a smaller engine. Try to clean all excess oil off engine and body. Then, if you can get it running....check for any leaks. If it is still smoking, it has other issues besides being too full of oil. The oil breather will be full of oil. The oil filter may be saturated with oil. Check those 2 things especially as they allow motor oil to be drawn into the carburetor and cause excessive smoking. Pull out and clean the spark plug. Post back if needed.
Aug 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Mower blows white smoke
Depending on how old is your mower, it could be broken rings in the engine, or just excess oil. I would recommend to check oil level first.
Hope this helps!
May 24, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Nov 17, 2009 | Craftsman Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
