Question about Shark Vacuums
Need to know if a part I found after I disassembled. And reassembled my shark professional liftaway navigator vacuum is critical . It's a white rubber gasket of some kind, half moon shaped
Check out above
  • Shark Master
  • 3,287 Answers
The gasket sounds like one between the motor housing and a detachable dirt cup. You didn't include a model number so it's hard to get into specifics, but if it is this gasket I'm speaking to - suction power will suffer and or dirt / dust will leak out. If a different gasket - it may not be noticeable to you that anything is wrong - but gaskets are usually critical components that are used to fill gaps that might otherwise allow dirt, water, dust etc. into spaces where it shouldn't.
Posted on Apr 17, 2015
Testimonial: "Thanks for the info, but I'm confused about just where it fits. Its a shark navigator lift away pro., model #nv356e, if that helps"
  • Steve Apr 20, 2015
    Without being able to see the gasket - it's hard to suggest places it would be installed. I would check around removeable parts that need tight fitting parts to maintain suction - such as edges / recesses of the dirt bin. Have a look at the manual (linked below), too. If all fails, you could contact Shark at 800 798 7398 http://www.manualslib.com/manual/558555/...
Filter ordered is too small and splits after two uses. What size to order?
Shark Professional Pet Navigator Lift Away Bagless Vacuum
Does it need a the filter since it is Bagless Vacuum??
Dec 06, 2015 | Shark Professional Pet Navigator Lift Away...
The power head has a device to hold the power head together what does it look like?
Shark NAVIGATOR LIFT-AWAY PRO NV355 Owner's Manual
www.manualslib.com/manual/.../Shark-Navigator-Lift-Away-Pro-Nv355...NAVIGATOR LIFT-AWAY PRO NV355 Vacuum Cleaner pdf manual download. ...Shark ® Getting Started Navigator ™ Mode 1: Upright Vac Lift-Away ® Mode 2: ...Important Safety Instructions - ‎Table Of Contents - ‎Ordering Parts - ‎Maintenance
Sep 22, 2015 | Shark Navigator Lift-Away Professional...
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Feb 22, 2015 | Shark Navigator Bagless Upright Vacuum
I think I may have a plugged hose. How do I take the handle off from the head to get to the hose?
Hi, it's Allie from Crucial Vacuum!
Your Shark Navigator Freestyle Cordless unit has a flexible air hose located on the floor base of your unit, which allows the air flow and picked up dust to travel from the floor through to the canister.
Accumulated hair strands and debris may cause this hose to be clogged, the dustcup inlet to be blocked or the brushroll to not run properly. Start with turning off your vacuum. Press the release button on the back of your unit's main body and remove the motorized brush. To reach and clear the air hose, flip back the connector to straighten the air passage and remove all debris or blockage found.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Shark Navigator Freestyle Stick Vacuum -...
Why does navigator freestyle shark vacuum light blink even after charged?
I have had 2 Shark Cordless Freestyle vacuums. The first one, when it was fully charged, the blue light would glow softly. The newest one has a flashing blue light that you can see from outer space. Light is supposed to keep flashing even when it is fully charged. Very annoyed that they changed this feature.
Jun 09, 2014 | Shark Navigator Freestyle Stick Vacuum -...
Shark replacement parts
Hi, it's Cindy from Crucial Vacuum.
You can purchase direct your replacement Shark Navigator parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=shark+navigator
Cindy Yuk
Apr 26, 2014 | Vacuums
Beater bar is not working
Shark Rotator Troubleshooting - YouTube
? 10:35
www.youtube.com/watch?v=H_dovG2javs
Oct 23, 2012 - Uploaded by VacBin
I show you how to fix common problems with the Shark Rotator..... I have Shark Rotator Prof Liftaway and ...
Feb 01, 2014 | Shark Rotator Professional Bagless Upright...
What's the link to register the shark navigator liftaway vaccum
Here is a tip that I wrote about how to find the parts you need for your Shark The link to register is there also... How to Find Shark Parts and Accessories heatman101
Apr 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
174 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
