Question about Home Security
How to unlock the security theft system - Home Security
What is the security code?
Your SECURITY light lit on the instrument cluster ? or you disconnected the battery an now the radio is locked ?
The theft deterrent system on this vehicle is comprised of the vehicle theft deterrent (VTD) system. VTD prevents drive away theft by preventing the vehicle from starting.
SECURITY Indicator The SECURITY indicator on the instrument cluster is controlled by the VTD system. The SECURITY indicator is located inside the instrument cluster. The SECURITY indicator is controlled by the body control module through the class 2 data line. The VTD system contained in the BCM commands the instrument cluster to control the SECURITY indicator only when the ignition switch is ON. The VTD system uses the indicator as a malfunction indicator.
Theft Deterrent
The "Theftlock" theft deterrent system is a feature on all base and uplevel radios. There is no need to program a security code into the radio as in past model years. The theft deterrent system now utilizes class 2 serial data to determine if the radio is in the appropriate vehicle. Each time the radio receives the "run" power mode message, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information. If a mis-match occurs, the radio display will indicate to the user the radio is locked. Once this takes place, a DTC will set, the radio will not respond to any button presses and become inoperative. The two scenarios able to cause this condition are:
A radio is installed from another vehicle.
A module which communicates on the class 2 serial data circuit which supplies VIN information to the radio is replaced and not properly setup with the correct VIN information for that vehicle.
The only way to unlock the radio is by using a scan tool. Always refer to the table in this section to diagnose the "Theftlock" DTC for further information.
So what problem are you having ?
May 01, 2016 | 2004 Pontiac Grand Am
How do you bridge-out the anti-theft security system....it keeps kicking in and shutting down the van after starting
There is a problem detected within the security system by the security module. Try locking and unlocking the door with the key fob to reset the system. Sometimes locking and unlocking the drivers door using the key will reset the system as well. If still no luck, try the spare key to see if the security system accepts it
May 02, 2015 | 2001 Ford Windstar
Why my key will not unlock my door manually on my 2007 ford edge.why the anti theft mode is on the dash.
The manual unlock is operated by a set of small levers in the door. Either the connecting rod between the key mech and the door lock has become loose or the mechanism inside the lock itself is faulty.
Modern cars don't like being unlocked manually, you might have tripped the security system by trying to unlock the door, which could be why the anti-theft mode is giving you a warning. It's usually more of a warning that someone has tampered with the door locks and couldn't gain entry or something like that. If your car came with a manual for the security system, read up on it.
Feb 18, 2015 | 2007 Ford Edge SEL Plus
How do i fix delco anti theft radio security system that won't stop flashing lights
Did you hit the remote button to unlock the doors.? Will the car start?
Jun 09, 2014 | Vehicle Parts & Accessories
I have a 1997 infiniti I30, one day all of a sudden when I came out of a grocery store I turned the key and absoloutely nothing happened. My lights can come on inside the car but, my power windows wont...
This is from Ken on CarPros:
Here is the way to reset the security system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Here is the systems descriptions
There are 2 security system, namely anti-theft and immobilizer.
Here are the 2 systems.
DESCRIPTION & OPERATION
Anti-theft system is controlled by Body Control Module (BCM). BCM receives signals from hood switch, trunk switch, door switches and Local Control Modules (LCMs). There are 5 LCMs located throughout vehicle.
To set anti-theft system in armed mode, remove ignition key, close all doors, trunk and hood. Lock doors using key or remote controller. The SECURITY light will illuminate for 30 seconds, then flash in 2.4 second intervals, indicating system is in armed mode.
To cancel armed mode, unlock and open any door or trunk lid using key or remote controller. SECURITY light will flash every second, indicating system is disarmed.
Alarm will activate (horn sounds, headlights flash and starter circuit is disabled) if any of the following conditions occur while system is in armed mode:
Engine hood or trunk lid is opened using the hood or trunk lid release.
Door(s) is unlocked without key or remote controller.
Tampering with any door/trunk lid key cylinders.
To deactivate anti-theft system, unlock door or trunk using key or remote controller.
If it is the immobilizer that is preventing the engine from being started, ensure you have the correct key and the transponder is intact. Quite often keys are dropped and if it breaks open, the internals would scatter all over. When this occurs, there is a tendency for the transponder to be lost.
Please let us know happens so it will help others.
Best, Ken
I hope that helps you out!
Mar 31, 2017 | 1997 Infiniti.5 J30
07 ford focus anti theft light flashes all the time
If the security or anti-theft light is flashing when you attempt to start your car, and the engine does not crank or does not start, you have an anti-theft problem. The system may not be recognizing your key's key-less entry signal, or there may be a fault in the anti-theft module or wiring.
There is a reset procedure to stop this anti-theft light flashing.many a times this helps The reset procedure is as follows:-- Reset the alarm by locking and unlocking the drivers side door.Do this a couple of times and then check it will reset the factory security system . If the reset procedure does not helps then its time to get the anti-theft system checked.There is a short circuit in the anti-theft system wiring. For more detailed help on this anti-theft light blinking issues please click on the link below http://www.aa1car.com/library/troubleshoot_antitheft_system.htm
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Cars & Trucks
1999 chevy malibu won't start
if your theft light is on you must disable the security system you have to use your remote to unlock the vechicle which will turn off the security system if your remote is not working you can unlock the rear hatch with the key and it will shut off the alarm if these things do not work you must have the security system read by a dealer to determin if the bcm is the cause the only other way to bypass it is to replace bith the bcm and the pcm with modules out of a vechicle without theft
Dec 15, 2009 | 2006 Chrysler Town & Country
Reset theft system on 96sable ls
security system malfunction
Oct 01, 2009 | 1996 Mercury Sable
Need to reset theft system 1995 jeep grand cherokee
Unlock and Lock the back hatch with the key from the outside.
Jun 27, 2009 | Anti-theft Alarm System 3 Series E90 E92...
1992 chevy corvettecranks but doe's not start.fuel pump not working but good.fuse good doe's not have power to fuse at all.
The built in factory anti-theft system disables the fuel pump if it is triggered, or this can be caused by a fault in the anti-theft, those are a few of the reasons, arm and dis-arm anti-theft is it working properly? Follow this procedure to check security system:
The Security System is reset by unlocking the driver's door twice with the Ignition Key, but if it does not reset, most likely the Ignition Lock Cylinder has failed. It has small contacts which 'sense' the pellet on the key and transmits that data to the Anti-theft Module. Often the contacts, or the micro wires, break causing the module to think you have no key in there. The ASR may be illuminating since the Security System is active, trouble codes?
Aug 04, 2008 | Chevrolet Corvette Cars & Trucks
Home Security Logo
539 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
