Question about Coby 40 TFTV4028 LCD TV
Can a tv inverter board cause tv to not display
Tv show blue coby screen then turns off changed power supply and main board wondering if it could be inverter board?
  • Ron g May 28, 2015
    I have same problem same TV I replaced the inverter board it did not fix the problem.
    New Friend:
  • 4 Answers
First you have to make some checks , play audio ? have to look at the screen closely and make sure there is image. If you have audio or image is not the main board , is the inverter . But if the logo is turned off and no picture or sound , it may be the main board. Discard the power board measuring voltages . Luck .
Posted on Apr 20, 2015
  • Coby Master
  • 4,103 Answers
Inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Posted on Apr 18, 2015
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
My tv has a black screen when turned on, I can hear sound and when i put a flash light up to it i can see the picture, which part do i most likely need to replace?
http://electro-medical.blogspot.com/
Mar 01, 2016 | LG 32LN5300 32" LED TV 1920x1080, 60 Hz,...
Why does it turn from blue to black after 10 sec.?
Dec 15, 2015 | RCA Televison & Video
Where can I find a service repair manual for Coby LEDTV1926?
this problem is coming from the main board or back light inverter
Feb 15, 2013 | Coby LEDTV1926 19 in. TV
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Proscan 47LB45H tv turns on , has sound , no video
Jun 19, 2017 | Proscan 47LB45H 47 in. LCD TV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
No picture
This is a power supply problem. Try to check the fuses ,fusable resistor ,capacitor and transistor in power supply board.
Regards,
VOTIT
Oct 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Picture washed out, can't get it right
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Coby 40 TFTV4028 LCD TV Logo
157 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
