Is the monitor 422 heater considered a direct vent wall heater
  • 3,289 Answers
Yes, the Monitor 422 heater is direct vent type.
You must install the supplied double-walled vent tube between the heater and outdoors. Failure to properly install the vent tube will quickly deplete oxygen from the space it is operating in. That is a potentially deadly situation.
The pipe is special. The inner pipe is for hot exhaust gasses to be sent outside and the outer walled pipe is for fresh combustion air to be brought into the heater. This set up is why the heater does not create drafts in the home.
Posted on Apr 17, 2015
Wall above Direct Vent Heater gets very hot.
Sense heat rises the only real way to help this is to put some sort of thermal barrier above the heater.
Mar 21, 2017 | Heating & Cooling
Monitor 30
I have one if your still looking $15 plus $2.00 shipping, email below
iamsearching2@yahoo.com
Mar 19, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
Where can i buy parts for my mpi monter 422
You can buy parts from me.
The more information about the part you can give me, such as the name, model #, model yr, serial # of the heater, along with the name, part # (if known) & location of the part, picture or photo of the part, & so forth, the better I shall be able to identify the part accurately & send it to you as efficiently & swiftly as I can.
Please send your inquiry to <TrailerParkOwner@hotmail.com>
Dec 08, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I just bought a used Rinnai 1004f propane monitor and it came without the vent to outside. How can I get a vent? (Maybe kit) The wall is 16 inches thick. Jim Marstaller Naples, Maine
is this a vented or non vented unit? have you checked the rinnai distributorship? call Adirondack Hardware in Keeseville NY. They have parts for Toyostove, Monitors and Rinnai heaters. Their staff are very well versed in all kero and propane heaters.
Oct 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Monitor 30, it comes on and just runs, it will not lite until I lift the primer once or twice, then it heats fine. I checked the filter and made sure the tank was high enough for a 5 gallon...
Rob,
You have some kind of fuel problem. When you mention 5 gals of fuel, that leads me to think you need more fuel ( more pressure). If you have a large tank and only have 5 gals you may no have enough head pressure to push the fuel through the line and all the filters in the system. That being said the Monitor 30 is the oldest vented heater around. Parts have not been available for 15 years. The thing that scares me about the M30 is the flame safety circuit. I don't think it is adequate. If you rely on this heater to keep pipes thawed I would get a new Monitor or Toyo.
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Mpi monitor 422 heat problem
I had the same problem last night and this morning. Its in the manual. I had to take the fan off of the back and vaccuum out all of the dust/lint that built up and it was a lot. It is a safety feature. It's a overheating protection feature that usually triggers if there is build up in the fan, front vent or vent pipe to the outside. I hope this helps.
Dec 26, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
B vent configuration of direct vent propane heaters
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Sep 17, 2008 | Empire DV-215 Direct Vent Natural Gas...
Procom fireplaces
Empire makes a wall heater that is direct-vent that looks similar to vent- free wall heaters. Here is a link to a website that sells their products... http://www.mastersalesonline.com/empire/index.html. I am not sure of the prices you will need to call the on-line store. I hope this helps you.
Jul 08, 2008 | Procom ML300TBA Heater
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
