Question about New Bright 1:12 14" R/C Pro Wolf, Flat Track Racer- All About Speed - 81210
I need a replacement screw that holds the wheel in place for a New Bright Wolf Pro. Does anyone know where I can buy one?
How do i remove the dashboard of my 02 bonneville?
Most all instrument panels are easily removed. there should be 2 or 3 Phillips or 7mm screws holding a dress ring in place remove tilt wheel down,(sometimes you must turn key and WITH FOOT ON BRAKE OR PARKING BRAKE SET,shift gear selector to "1" to get it out of the way) remove dress ring. then there will be 4- 7mm screws holding panel in place, remove those, pull panel out a little ways and unplug electrical plug-in, you can unhook positive battery cable if you want but is not necessary, then remove instrument panel. reverse sets to install new panel. please rate my answericon1.png, thank :-)
May 07, 2014 | 2002 Pontiac Bonneville
So. I took the Body cover off My New Bright Wolf Pro R/C Truck And The Red and Yello Wires came out the back, I thought they went to the motor, but they dont.. They go to a sencer of some kind for the...
The sensor is a resistive load sensor. The resistance changes as the motor gets hot. Solder the wires back onto the board and whilst keeping the model off of the ground, put it into drive mode. If it doesn't go, then wet your finger and bridge the two solder points on the sensor. Don't worry, you will not get any electric shock as the voltage and current are too low.
If it still doesn't drive, then wiggle the motor wiring at the motor. If still nothing, then press lightly on that sensor pcb. There may be a broken track on it. If it is broken, then you cannot solder it. You then need to go to Maplins (if in the UK) and buy a small bottle of pure silver paint. Where the solder points meet the circuit resistive track (it'll be black carbon looking), paint one blob of silver conductive paint onto each of the track beginnings. Let those dry (five minutes) and then try it. It should work. The silver paint will only work if the wet finger trick on the black carbon track works. If no carbon track, then it may be a thermal resistor (thermistor). Replace it. Maplin sells them too, so just buy a few different types (very cheap) and temporarily solder one in place until it works.
Aug 19, 2013 | New Bright Remote Control 1:12 Scale Pro...
How to fix needle on a machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
here's a link for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
I have an ancient Willy Wolf shoulder rest that was passed down to me. One side needs a new set screw and the sleeve is missing. Where can I buy new parts? The local hardware store says it's a...
It is not clear exactly what parts are missing. If you can find the screw or thumbscrew part, consider MAKING YOUR OWN sleeve...Possibly use a short length of copper tubing or cut a piece of rod and drill a hole in it for the sleeve... Sometimes for a spacer we have just stacked up several small nuts... better than spending $50 for whole new rest.
Sep 19, 2011 | Wolf Manufacturing Willy Wolf...
How do you replace the ignition lock cylinder for a 1972 Corvette? The cylinder is stuck in the lock position and even with the key inserted it will not turn, thus locking the steering wheel and vehicle in...
Try and turn the wheel from side to side while turning the key as it may be jammed on the locking pin... If that's a no go then you must remove the steering wheel and signal switch to access the screw that holds the cylinder in place. If you must remove the wheel go to a parts store and buy a lock plate installer to remove the circlip that holds the lock plate compressed.
Jul 28, 2010 | 1972 Chevrolet Corvette
1995 olds alero; how to repair a brake sensor....car shop
YOU HAVE TO REPLACE WHEEL SENSOR.IF THE BOLT HOLES BROKE.THAT HOLDS IT IN PLACE.NOW IF YOUR WHEEL SENSOR SCREWS MISSING YOU NEED TO BUY THEM AT DEALERSHIP OR SALVAGE YARD.BESURE TO GET SCREWS BEFORE PUTTING A NEW ONE ON.WITH OUT THIS SENSOR IN PLACE IT WILL CAUSE ABS BRAKE PROBLEMS.
Aug 04, 2009 | 1999 Oldsmobile Alero
Bright lights
you most likely need to replace the turn signal switch, also known as the headlight module. you have to remove the cover from around the steering column. there are usually phillips screws going through the bottom of the cover that hold it in place.
Apr 24, 2009 | 1994 Chevrolet Beretta
The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
Which are retaining screws for dvd on aspire 9300-5317
You will be better off buying a drive from the manu. As for the screws any screws you remove from the outside should not be holding the motherboard. If you question the screws take them both out but make sure not to jar the thing too bad until you have the new drive in place and screwed back down.
Dec 01, 2008 | Acer Aspire 9300 Notebook
Lost screw to front floor nozzle.
Go to http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
and click on parts & accessories.
Aug 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
New Bright 1:12 14" R/C Pro Wolf, Flat Track Racer- All About Speed - 81210 Logo
329 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
