Question about Echo Garden
Ok I found this one.I think its an aftermarket brand. Will this work with my Echo Cs-400, also after install do I need to get the compression check? Thanks in advance!
    Top Expert:
  • Echo Master
  • 44,274 Answers
If it is the same dimensions and shape it will work on your machine
as to the compression test, if you have resistance after installing the plug you have compression
note-- when installing the ring , make sure that the ring ends are either side of the location pin in the ring groove
Posted on Apr 19, 2015
  • Love Joy
    Love Joy Apr 19, 2015
    Ok..Thanks!
    Top Expert:
  • Echo Master
  • 10,875 Answers
Yes!!!!!
Posted on Apr 18, 2015
  • 1 more comment
  • Love Joy
    Love Joy Apr 18, 2015
    Hello. Are you saying yes to both questions. ..compression as well?
    Thanks
  •  johnny rebel
    johnny rebel Apr 18, 2015
    use it,dont worry about compression,make sure you stagger the rings,gap on different sides
  • Love Joy
    Ok...thanks! I just purchased it!
  • 63 Answers
SOURCE: Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Posted on Mar 16, 2009
  • 63 Answers
SOURCE: My Echo CS 440 will not start
Pull the spark plug, dump in about half a teaspoon of fuel and try to start it. I think you have a carb problem or low compression.
Posted on Mar 21, 2009
  • 4088 Answers
SOURCE: BRAND NEW ECHO CS-600P HARD STARTING, HAVE TO PULL
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Posted on Nov 03, 2010
eugbug
  • 479 Answers
SOURCE: Brand new Echo cs-400 chain
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
Posted on May 12, 2011
  • 6468 Answers
SOURCE: Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
Posted on May 27, 2012
Why does derate lose power?
OK things to check. Gas/Oil mixture make sure you mix it in right amount. Be sure chain is NOT too tight. Now be sure to let the saw do the work . if you put too much pressure on it or,the chain is dull , the saw will loose power. Let me know how it goes.
Dec 03, 2015 | Echo Cs-400 18" Gas Chainsaw 40.2cc Sealed
I received the cylinder assembly today. And when I opened up the package everything was there, but the ring for the piston was broken in half :
OH well free replacement is what you want then you will wait and why did you order from GREECE in the first place .
May 04, 2015 | Echo Cs-400 Chainsaws
May 25, 2012 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
May 12, 2011 | Echo CS400 18" Chain Saw
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Trying to replace gear on echo cs 440 chain saw and not sure how to remove old gear
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Jul 02, 2009 | Echo Garden
Mar 21, 2009 | Echo Garden
Garden Logo
98 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
