Question about Health & Beauty
I have this red bump with 3 white pus looking bumps on my leg can you help me figure put what it is ...
  • Jim Evans Apr 17, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? This is also posted in the wrong area.
    Top Expert:
  • 6,702 Answers
Please visit a GP or a doctor. The internet is not a replacement for this. Don't play with your health. A picture is 2D and only a spot. A GP looks at more than the bumps and needs more than that.
Posted on Apr 17, 2015
  • 11 Answers
SOURCE: Blower fan goes off with hitting a bump
Check to see if any of the wire connections are loose.
Neil
Posted on Mar 15, 2009
batviper
  • 120 Answers
SOURCE: left front end noise over bumps.
sounds like a bad shock or broken sawey bar
Posted on Nov 17, 2009
  • 340 Answers
SOURCE: when brakes applied it goes bump bump bump. the
first of all what machine did you put it on
front end aliment won't help you if that is what you did. sounds like a rotor or bearing or even the cv halfshaft last but not least check your engine & trans mounts they are hydraulic and can lose there oil
Posted on Feb 24, 2010
  • 1619 Answers
SOURCE: 1993 mercedes 190e 2.3/a bump bump bump when i aceelerate
Sounds like a driveline type issue. Check carrier bearing and flex discs.
Posted on Jul 17, 2010
NomadTrucker
  • 166 Answers
SOURCE: Have a 3/4 ton dodge 2004 diesel . It makes
Jack up the truck let the wheels hang in their suspension - then look put a long strong rod / pipe / plate underneath one wheel and listen for unusual noises when the wheel is lifted. Check for noises when the axle is pressured again by the weight of the truck.
Posted on Jun 26, 2011
Hi, I have a red extremely itchy bumps in various sizes all over my legs and stomach. They are so itchy that I scratch until they bleed. I have had this problem for over 2 years. I have seen a number
I am not a doctor but this may be a violent allergic reaction to something in your food or environment (Wool , Pesticide, Air freshener , Deodorant, Cleaning chemical )
I think you should go down a direction of getting allergy tested to see if you have an allergic reaction .to something
http://www.labtestsonline.org.au/learning/index-of-conditions/allergies/tests?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nJRaOtlFQyhmJn62_erTUdasxpd8Ul93WYxZNXdOnvoaAvA_8P8HAQ
I have done the VEGA testing and it does highlight allergies and mineral and vitamin deficiencies usually a natropath does the vega testing just internet search vega test
Mar 10, 2017 | Health & Beauty
Does it matter what kind of razor I buy for shaving my legs? I tend to buy really cheap ones but keep getting red bumps on my legs. Is the razor the cause?
Cheap disposable razors tend to be straight and single bladed. I would really spend the money on a better quality razor that has multiple blades and a pivoting head. You can get specific women's razors and the good quality ones should last quite a while. This might make a big difference to you in cutting back on sores and red bumps.
Feb 14, 2013 | Health & Beauty
What are ingrown hairs? I have a few really sore pimple type spots on my legs and they are really sore. Is this from shaving my legs?
Shaving can cause ingrowing hairs. This happens when the hair that is cut curls back and grows inwards. It shows up as pimples or bumps and can look red and inflamed. If it's a constant problem or gets infected, you may need to get advice from a dermatologist.
How to replace a fuse on a bose sounddock
Assuming you have a Sounddock Series 1 the Low end Bump -Bump, nine times out of 10, the Bump is the power supply connector inserted in the wrong orientation. Check you have the plug correct. If it is correct then look on www.invebo.com for the diagnostics video.
Feb 28, 2012 | Bose SoundDock Digital Music System for...
Idle is high at start - 1800 rpm. Seems like excessive white smoke from exhaust. Put into reverse and back out of driveway it has a regular shudder (bump bump bump) but not hard metal grinding sound.....
white smoke out of the exhaust would be a sign that it is burning coolant... if it goes away after it warms up, it could just be condensation inside the exhaust pipe. 1800 rpm is a very high idle, maybe have your IAC motor on the throttle body checked... check engine light? if so have the code read at your local auto zone.
Aug 09, 2011 | 1998 Toyota 4Runner
Need to get my hands on a manual for a mazda b2600. Just put a new head gasket in it and the timing is all out.
take the spark plug out of the hole on the engine. the very front plug.
have someone bump the engine for you. take the cap off of the distributor, and when your friend bumps the engine watch the way the rotor is turning. i think its counterclock wise. but anyway, hold your finger over the spark plug hole and have the friend bump -bump- bump the key until the air pressure "Pssst" blows your finger out of the hole. thats the compression stroke of your engine. and right now its set to send a spark to that #1 piston.
SO look at the rotor, and pay attention to what direction the rotor is pointed. and when you put your distributor cap back on, your wire for #1 spark plug has to be pointed at the rotors tip, to get spark. so put cap back on, and then put #1 at the rotor tip, and remember what direction the rotor spins ? now put your spark plug wires on the cap to match the "firing order" The firing order is 1-3-4-2 with the cylinder closest to the front of the vehicle being #1 so if the rotor spins backwards . wherever the rotor tip is now ( since you bumped it to the compresson stroke ) on the #1 cylinder, you know where 1 is. now put #3 piston wire on the next plug, on the distributor then 4 , then 2. tighten everything, put the spark plug back in. and start your truck bro.
Jul 31, 2010 | Mazda B2600 Cars & Trucks
I have an intermatic timer 5 wires hooked up 2 white to # 1 one red to #2 and a red to #4 #3 is blank on & off works but timer isnt spinning
Give me the model number and i will look up the wiring diagram to confirm how to wire this. There are lots of different models. On some of them you need to supply a jumper wire between two terminals in order to power the clock motor. Some also had DIP switches to be set.
Jun 23, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
A friend bumped into my Toshiba 61HX70. Now the
Convergence is off. A tech can help resolve the issue.
May 27, 2010 | Toshiba 61HX70 61" Rear Projection...
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Health & Beauty Logo
216 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
