Question about Crock Pots & Slow Cookers
I am looking for the CPC-PT600 Cooking Pot - Crock Pots & Slow Cookers
When cooking pork chops in crock pot,can the chops be layered or must they all be on the bottom of the pot? I am cooking 7 3/4 Chops?
sadly this is not a cooking help site . but if you tie them together as a roast and cook for a long time 7 or 8 hours they will all be done per my wife
Nov 24, 2016 | Crock Pots & Slow Cookers
Why do my roast potatoes take two hours to cook what am i doing wrong, cooking at190 degrees
I'm not really an expert in cooking and I've never roasted potatoes in some Crock Pot or Slow Cooker but for sure you need more then 190? (guess F?) to roast potatoes.
You should look up a receipe book for your device, like this one:
http://www.crock-pot.com/recipes.html
Aug 23, 2015 | Crock Pots & Slow Cookers
How to fix on a ninja crockpot e01
According to the manual it means the cooking pot is not inserted into the device.
Mar 19, 2013 | NINJA SEARious Slow Cooker
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
How can i switch my rival programmable crockpot to warm? It was cooking too long and I'd like to switch it
A crock pot is an ALL DAY cooking methodology and should not be altered. Fire and personal injury are possible results.
Oct 17, 2010 | Rival 38601 Smart Pot 6-Quart
Metalic after taste when cooking soup.
If you're using spoon made of metal to steer it while cooking than it might be some chemical reaction between the spoon and the pot due to salty fluid. Try using wooden steerer.
Apr 11, 2008 | Rival 38601 Smart Pot 6-Quart
RIVAL Crock Pot 3350 - Replacement of Cooking Pot
same, it was given to me as a gift from my aunt a very long time ago, just last night the liner broke. Where can i go to find a replacement liner?
Mar 05, 2008 | Rival 33511 5-Quart
Warm setting
Units such as the "Countdown" and "Recipe" Smart Pot™ slow cookers have a designated warm setting. Basic Smart Pot™ slow cookers have an automatic warm feature that activates a keep warm function when the cooking time expires. This type of warm feature will not activate without the set cooking time expiring first.
Feb 10, 2008 | Rival 38601 Smart Pot 6-Quart
Slow Cookers
Howabout if you try go online on the internet and search for cooking foods in a crock pot? Your answer will be there.
Happy cooking, Spurs21
Feb 23, 2007 | Rival 38501 Smart Pot 5-Quart
Crock Pots & Slow Cookers Logo
107 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
