Question about Trend Enterprises Inc Trend Enterprises Solar System English - Spanish Guide Bulletin Board Set T-8014
There is a small rod w/spring that was misplaced during battery replacement. Can a replacement be purchased?
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
How to replace the piston and rod assembly
Many small hobby machines have a chamfer at the cylinder base to act as a leed into the cylinder, just make sure the piston rings are located properly, there will be a small peg in the piston to stop the rings rotating, the open ends of the ring should be cenral to this pis so as the ring compressis, if there is no leed in the cylinder you will need to use a ring compressor, these can be purchased in kits are are fairly inexpensive, make sure you oil both piston and bore before assembly.
May 02, 2012 | Craftsman Gas Mini - Tiller/Edger
Vehicle violently vibrates when hitting a small bump or hole at times. Trying to slow down the car only makes it worse during these episodes and steering is very difficult. What can cause this
Check out the 'front end' at a garage to do a thorough shake down of components such as springs, tie rod ends, ball joints, shock absorbers, steering rods, bearings, etc.
Jul 05, 2010 | 1996 Jeep Grand Cherokee
What connects the throttle linkage to the carburator? is it a spring or rod
It's actually a combination of both. There should be a small rod at one side of a small plate, (which acts like a cam) and a spring on the other side. The throttle cable pulls the plate and rod, expanding the spring at the same time. When the cable is relaxed the springs pulls the linkage back.
Mar 16, 2010 | Pool & Spa
The spring attacted to the drum has come undone. How do you replace it?
Hi Sleepy.
When you say "spring" are you talking about the small spring attached between the left-front shock rod and the small red tab on the tub rim, or are you talking about one of the tub support rods/shock absorbers? If it's the latter, it has probably broken and has to be replaced. What I usually see happen is that the rod pulls right out of the angular bracket that supports the rod. if the rod came undone it is very easy to re-install it, you hook the bottom round "bearing" onto the tub, lift the rod up and set the angled bracket back into the corner of the cabinet. if this angled bracket is still attached to the corner and you see a rod and spring, then you broke the shock rod. If this is the case, they are sold in sets of 4 and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=218&category_id=54
Mar 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Makes knocking noises during wash cycle.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2009 | Washing Machines
Need replacement part,a spring for Evenflo Exersaucer Mega Activi
Check thier website. You can enter in the model # and date of production (seat ring that the cloth attaches to). From there it'll show you all the available parts for purchase. You can also find/buy replacement or "switch a roo" toys from their website. I found this by googling "replacement parts for evenflo excersaucer".
I hope this helps!!!
Jan 04, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
EXTREME SHAKING DURING SPIN CYCLE
Dec 27, 2008 | Washing Machines
Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Oct 07, 2008 | Kodak EasyShare DX7630 Digital Camera
Trend Enterprises Inc Trend Enterprises Solar System English - Spanish Guide Bulletin Board Set T-8014 Logo
433 people viewed this question
Top Trend Enterprises Inc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Trend Enterprises Inc Office Equipment and Supply Expert? Answer questions, earn points and help others
