Question about Craftsman Garden
I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
Posted on May 20, 2015
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Have a craftsman 32cc craftsman model #358791060 I have changed gas lines and is hooked up properly but when I prime the bulb the gas pours out of the carb. Any suggestions as to how to fix this?
Although you think you go it connect correctly, it sounds like you got the primer connected backwards.
Here is the basic layout for a remote primer system.
Apr 17, 2015 | Craftsman Garden
Hi pmbaugardne...
Sep 19, 2011 | Craftsman Garden
Model no.358791072 fuel lines were rotted.I need a diagram of the proper order
Hi and welcome to FixYa, I am Kelly.
The fuel line WITHOUT a strainer will go from the tank to the OUTSIDE primber bulb connection then from the primer bulb center connection to the carb. Item 7 this link comes with the diagrams:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791072/0247/1503820/P0808034/00002?blt=06&prst=0&shdMod=358791072
There are several you tube videos here on replacing fuel lines:
Something to note... inside the tank there is a fuel filter/strainer. Make sure to replace that fuel line also. The connection from the strainer will connect straight to the carb fuel mainfold connection. The center connection of the primer bulb will go straight to the carb fuel manifold.
http://www.fixya.com/uploads/images/1CE2BC8.gif (Expand to 200%)
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
My craftsman 32cc weed wacker (model#358.791071) dose not start.
Many things to check. Spark, fuel and compression. Check these to narrow it down.
Nov 27, 2010 | Craftsman 25cc Gas Line Trimmer
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
249 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
