Question about Task Force 2000 PSI Electric Pressure Washer NEW 6127
Will not build up pressure sounds like it is but as soon as you hit the trigger pressure goes away
Put a new gun and hose on it also has a small leak where hose hooks up
    Problem Solver:
  • 17 Answers
Is this something new happening?
These machines quickly (a matter of seconds) build up to pressure and shut off. A slow leak is not much of a player. Eventually the pressure will bleed off and the pump come on (for a few seconds).
Pressure restored, should be good to go. Have you cleaned the inline filter to the hose. If there is a short burst of water then a dribble with a new hose, the filter is a first check
Posted on Apr 17, 2015
My washer makes a loud pulsing noise when not being used,as soon as I pull the trigger it works fine.
sounds like your unit has a bypass problem either needs adjustment or replaced
Oct 14, 2012 | Karcher Garden
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
I've got the: Dewalt Heavy - Duty 31° Clipped Head Framing Nailer - D51822 As soon as I hook up the hose to it there is a leak some where. It's faint but makes my compressor kick on immediately. I...
Don't know if this will help you but here goes. I have a Bostich nailer and had to replace the check valve under the trigger.(at least it acts like a check valve, stops air loss when disconnecting gun from hose) It was leaking badly and had to remove trigger to replace the kit. You can do it yourself like I did or take it in to a shop. I carefully punched out the roll pins, replaced the kit after greasing the o-rings with lubricant that was supplied with kit and replaced the trigger.
Good luck
Dec 09, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
No pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
I cannot put the cable in the power jet handle it will not go in
Please call us at www.rjbowers.com to have someone help with the problem. It sounds like the hose will not attach to the trigger gun. Have trigger gun near when you call 1-800-383-6584 to help solve your problem.
May 11, 2009 | Karcher K2.26 Electric Power Washer
Builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Mar 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Task Force 2000 PSI Electric Pressure Washer NEW 6127 Logo
243 people viewed this question
Top Task Force Garden Experts
Tom Chichester
Bill Boyd
Are you a Task Force Garden Expert? Answer questions, earn points and help others
