Question about Hitachi Tools & Hardware - Others
The fan and shaft falls out of the motor of my hitachi gc2 nailer ,how can I fix it
2 Suggested Answers
Mark Steele
  • 6 Answers
SOURCE: Hitachi roofing nailer leaks air
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
Posted on Aug 10, 2012
My hitachi nail gun won't fire,I opened back up and fan is lying loose inside.Can I fix this
YES always replace the parts and keep safety for all if in doubt clean regulary the cilinder internally because its very thin These cylinders break easily if something is faltering.
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=NT+65GS&newwindow=true
Feb 25, 2016 | Hitachi Tools & Hardware - Others
1st and 2nd fix bostitch nail guns same fault fan falls out
contact manufacturer tell them they are less than 1 yr old and tell them you want better ones,it works for me everytime
May 27, 2015 | Stanley Bostitch GF33PT Cordless Paper...
Hitachi nr 90 gc2 nailer wont fire
Various reasons, secondary switch faulty. gas out of date, gas is colld, iar leak, faulty spark unit.
Suggest you get it checked out at a repair centre.
Jan 04, 2013 | Hitachi NR90GC2 Cordless Gas Clipped Head...
I cant get my driver back into a nv 45ab2,,,it was kind of hard to pull out and sounded like it was compressed into it
it sounds like the shaft may be damaged, check for burs or tip wear/deformation; lubricate it well and some nailers require precise positioning of the drive to get it thru the seals. The lower seals may be damaged or out of place; brushing the shaft with synthetic steel wool would not hurt..
Oct 02, 2010 | Hitachi Nv45ab2(s) Coil Roofing Nailer
I have a CP-x2010 N Hitachi projector and yesterday when I tried to turn it on it started out green but the fan kept making noise like it couldn't start up all the way. A red light came on for the power...
The cooling fan can be lubricated by peeling off the round label. If the motor shaft can be seen, use a drop of sewing machine oil on the shaft. If you can't see the shaft, there is a rubber plug covering it. Use something sharp to remove it then put a drop of oil on it. This is not a permanent fix, so order a new fan and replace it when you get it.
Jun 08, 2017 | Hitachi Office Equipment & Supplies
I have a hitachi 2nd fix gas nailer and im not sure were ,and how often to apply the oil as iv managed to lose the instructions . hope you can help
Depending on how much you use the tool. Only apply oil to tool after you have given tool a strip and clean. Or for General maintence just 4 - 6 drops of oil every 3 - 4 week only if you use tool more then 3 times a week( 10,000 nails).Only on the fan assy O-rings.Remember this is only a guide.But if you need more info then try the hitachi web sit or your nearest nail gun repair agent.Good Luck
Nov 01, 2009 | Hitachi Tools & Hardware - Others
Paslode angle finish nailer the fan wont run nor will it shoot
have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
Feb 27, 2009 | Omega Paslode 901000 Impulse Cordless...
Tools & Hardware - Others Logo
99 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
