Question about Aqua Vac Tiger Shark
Unit moves forward then stops. will not mo0ve after this
Checked impeller. would not move initially but then got it to move in both directions with some restriction
1983 Johnson outboard . Model J25TECTE. Runs Forward/Reverse. Shift rod connection OK. Shift in neutral it runs in reverse. Do I need to change something in the gear case section?
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
Jul 07, 2016 | Boating
Brand new Sharp Fridge Freezer Clicking noise
Make sure that the unit have adequate ventilation at the back , move the unit forward a few inches ( in your direction , standing in front of it) Make sure the unit don't touch anything surrounding it ..
Dec 03, 2013 | Refrigerators
What could cause my drivers side power seat to stop moving forward and backward?
sounds like you might have a switch problem if the memory for seat position works ok. If you have a multimeter that checks for continuity then you could start there at the switch but you would also need a wiring diagram for the seats
Mar 16, 2013 | 2001 Acura MDX
When the cycle has finished and I open the door the washing tablet is sitting in the tablet flap that is open
Hello Vanessa,
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not dissolving the detergent, it often is a busted wash impeller within the main motor/circulation pump.
Unfortunately the impeller itself is not serviceable, the entire motor/pump must be replaced if indeed it is broke.
Here's something you can try first though, this will indicate if the unit is circulating the water properly. Try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't.
Also be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Apr 19, 2011 | Asko D1716 Built-in Dishwasher
The dishwasher does not work at all. It just makes a slight hum.
Welcome to FixYa.
It sounds like you may have a faulty fill valve or a stuck motor impeller. I guess the first obvious question is, Does the unit fill with water ? If no and it hums, faulty fill valve or water supply is off.
If it does fill with water does the humming begin after it has filled, and if so has the unit recently been idle for a period of time...say a couple of weeks or so ? If yes, the wash impeller has become stuck and there is a simply resolution for Bosch dishwashers, it's a common occurrence.
These are relevant questions and can point directly to the problem if you want to reply I can help you move forward.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch SHU9915UC Dishwasher
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
The power light is on but the unit will not move forward or backwards. It just stopped working. I clean everything with a shop vac. When paper is initially installed you hear a click but no movement of the...
If the shredder won't move in either direction,it's usually a sign of a jam. Unplug the unit, turn the head upside down and with a small knife, flathead screwdriver, or tweezers, dig the remaining scraps of paper from the teeth. It's time consuming but eventually, there should be more pieces from underneath the head that are the actual cause of the jam. If when all (or almost all) of the paper is removed the shredder motor still won't engage, then in all liklihood the motor is dead. I hope this answers your question.
Greg
Nov 23, 2009 | Audio Players & Recorders
Dont move forward.
Blow out the unit with compressed air, particularly around the wheels and under the bumper. Tap the bumper with your hand.
If your Roomba stops and beeps at you, count the beeps AFTER the initial "uh-oh" tone. Then call customer support (1-877-855-8593) for assistance.
Good luck.
May 29, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 | Garden
Won't load DVD for Initial IDM-7110
First check and see what is happening inside. Take something small and stick n the lock mech, which is the hold that a small part of you top to the player sticks in to tell the unit that it is closed. See if the lense light up and moves up and down and also see if it moves forward a bit and back to start position. If player does not do any of this then with fingers move lense down line abit to see if anything is obstruting path. You can move all the way down then place DVD in and try again
Aug 14, 2007 | Initial IDM-7110 Portable DVD Player
Aqua Vac Tiger Shark Logo
264 people viewed this question
Top Aqua Pool & Spa Experts
Ben Clacy
Ben Clacy
Level 1 Expert
ray gallant
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
