Question about Autoart Suzuki Gsx 1100s Katana 112 Diecast Motocycle
Bike got spark but still dont start - Autoart Suzuki Gsx 1100s Katana 112 Diecast Motocycle
How do I get my bike started it turns over n gets fuel but just doesnt fire up
wrong forum this is Suzuki, not bikes.?
post to your bike class for best answers. and 100x faster
no starts, or no crank?
if it cranks and dont start then , check spark next.
all gas engines, same, only (what makes spark and fuel change)
Apr 29, 2014 | Suzuki Grand Vitara Cars & Trucks
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Jun 02, 2012 | Suzuki DR 750 S Motorcycles
83 xr200r runs for awhile then stops and wont start for awhile
Sounds more like the coil is causing your problems. It overheats and causes the misfire you experience. Coil cannot be repaired. Needs to be replaced. Once the bike has died, take the plug wire off, remove the sparkplug and reinsert the plug into the plug wire. Now let the plug rest on the head. Metal part should be touching the head. Try to start the bike again. The bike wont start of course but you should see a blue spark between the electrodes of the spark plug. If not, swop the plug with another one. If you still dont see a spark it is probably the coil. Other possibilities are the generator and/or condensor.
Jul 25, 2010 | Honda XR 200 Motorcycles
Bike dont start. Yamaha 175 CT - 1973 make.
Firstlly have you a spark at the plug.if you have no spark then it may be your points or even the timing may be out .
Mar 10, 2010 | 2004 Sym Husky 125
Suzuki bandit 1996 will not start
If you have spark and still the bike is not starting ( and the timing on the spark is correct) make sure you got fuel flowing to the engine, if fuel is getting there and still the engine doesn't start, check the cylinder head and pistons and make sure you got compression. These are the problems that can cause a bike not starting. Hope it helps
Mar 05, 2010 | 1996 Suzuki GSF 600 S Bandit
Have a 1992 suzuki 125 rm bike cant get it to
try changing gas . dont forget to empty out carb bowl also check for spark might have a fouled spark plug .
Jan 03, 2010 | Suzuki RM 125 Motorcycles
We bought a brand new Dirt bike, 110cc SSR and it will not start. I dont think we are getting a spark.
check the spark plug , and the ignition system for loose wires then connect , don't forget the battery if there is no current then charge.
Jul 09, 2009 | Pit SSR 110CC Pro Beginner Bike
T140 , no spark!
cracked coil/connection?
Jun 14, 2009 | 2001 Triumph Triumph Bonneville
2003 883 sportster wont start
What u are describing is typical of a faulty ignition system, but could also be a fuel problem. I check by removing the aircleaner and rotating the throttle. If u see a nice spray of fuel, thats probably not the problem. Check for a spark at the plugs. I can explain how if you need me to. If you cant see a good spark, U have an electrical problem. I had a crank position sensor go bad on me. Dont do what I did (replaced the battery, ignition, and regulator as part of my diagnosis procedure)
Nov 08, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Autoart Suzuki Gsx 1100s Katana 112 Diecast Motocycle Logo
329 people viewed this question
Top AutoArt Toys Experts
Andrew Taylor
Andrew Taylor
Are you an AutoArt Toy Expert? Answer questions, earn points and help others
