Question about Garden
John deer rx75 gets warm shuts off - Garden
  • 42 Answers
SOURCE: Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Posted on Apr 01, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
thefifthpowe
  • 10 Answers
SOURCE: instructions to replace starter on JD RX75 lawn mower engine
DID YOU TAKE THE TOP COVER OFF THE MOTOR? AND THERE IS ONLY ONE WAY THE STARTER GOES OTHERWISE IT HITS THE SIDE OF THE ENGINE.. i REPLACED MY STARTER FEW MONTHS AGO.. tHE STARTER WIRE HAS TO BE ON THE OUTSIDE TOWARDS THE OUTSIDE BODY....
Posted on May 02, 2012
SOURCE: john deere lt155 lawn tractor shuts off when it
My John Deere LT 155 runs then shuts off. If i put gas in carb, it starts and runs until the gas goes out. I loosened the gas tank cap and removed, it still runs then stops. The filter appears ok. Any thoughts?
Posted on Jul 18, 2013
Service or part manual for Kawasaki 9hp fc290vbs10 engine that's on a John Deere rx75
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Nov 07, 2016 | John Deere Garden
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 adjust belt tension
Best Manuals
Apr 21, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
How do i get the rear wheel of my john deere RX75
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
Jul 04, 2012 | John Deere Garden
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
