Question about HP Computers & Internet
Hp pavillion laptop allows me to log on. Then as it loads up screen flashes and a blue circular disc appears by the curso. It says limited wifi. No problem with the WiFI connecting my phone to it.
    Top Expert:
  • HP Master
  • 6,702 Answers
Does your phone use the Wifi antenna from your laptop? or the receiver? or the software? When your laptop indicates it has a problem with the Wifi connection, it has. What is causing this should be looked after in the laptop, like did you setup the connection correct? Is the setting still correct? or did something change the settings or even reset the settings?
Just check everything about the wireless connection in the laptop to see if you can get it working again. If it was never working before, just setup the connection.
Posted on Apr 17, 2015
Murphybanton
  • 2004 Answers
SOURCE: the wifi on my hp pavillion notebook dv9000 wont work
Please just runsystem restore to factory default and remember to backup your documents.
Rate this.
Posted on May 25, 2009
  • 4090 Answers
SOURCE: How to tell if my laptop is wifi ready
In your operating system go to control panel and follow the prompts of the network setup wizard ( select wireless setup) and follow the steps of the wizard. But you better have a wireless network type card in your laptop.. Usually there is a little switch on the unit soemwhere that displays an orange or blue light that is the network card.
Posted on Sep 18, 2009
SOURCE: I have a Lenovo Y430 notebook and it was working
After making sure that the status of network adapters in the device manager showed enabled, I tried using the Fn+F5 key on my keypad. The Fn+F5 key showed my WiFi status as disabled inspite of the Wifi toggle switch on the front of the laptop in the "on" position. So I enabled it and the WiFi led started glowing and I was able to access the internet through WiFi connection
Posted on Oct 14, 2009
SOURCE: my hp nc6000 wifi is not working as no light turns on even
try to reinstall your Wireless network setup
here's the link of your laptop driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
Posted on Jan 17, 2010
etaf
  • 779 Answers
SOURCE: HP Pavillion dv4000 is not able to connect to WiFi
169.254.x.x. is a valid IP address that windows aupplies when it cannot find a DHCP service
A few things to try
This is quite a long reply and may appear very technical - however, have a read through and see what you can do Answer.The following assums that your wireless connection is working and other PCs are able to connect:
There could be quite a lot of reasons you are not getting a connection to the wireless - some common issues
  1. the wireless is switched off
  2. Firewall may be blocking
  3. Remove profile
  4. Check Device working in Device manager
  5. Something else on the PC blocking
so quite a few things to check - so lets start in order
  1. Wireless Switch:- Most laptops have a wireless switch - some use a physical switch, other use a combination of the FN key + one of the F keys to toggle on/off - make sure this is on
  2. Firewall:- The firewall my be blocking access - try to disable the firewall. Often programs like Norton, Mcafee etc, when the subscription runs out can cause issues and need to be uninstalled, to uninstal you may need to use the removal tool available on thier websites. One of the ways to test this, is to do a PING test. Press the "Windows key" {bottom left of the keyboard} and at the same time press the "R key", now in the search box that appears - type "CMD", a black box will now appear on your screen, in that box type the following "ping google.com" if you get 4 replies then you can access the internet and your firewall may well be blocking the access try disabling the firewall.
  3. Remove wireless profiles http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  4. Have a look at device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc and see if you have any ? X or ! look under network adapters - click on the + and see if you have the adapter listed It will have a name something with wireless or 802.11 B/G/N included - check if it has any X or ! or ?
  5. safemode:- Try to boot the PC into "safe mode with networking". To do this switch the PC on and now as it starts keep tapping the F8 key untill a menu appears, from that menu choose "safe mode with networking". If you can now connect to the internet,then there is something blocking your access on the PC when it starts normally - post back a comment and if that's the case, We can try doing a "clean boot" and try to identify the startup or process that is causing the issue
A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC thats not working and install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. Which will prove the hardware works.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Apr 03, 2010
I have hp pavillion DV6-6c35dx black screen with caps lock blinking twice to indicate corrupted bios. How do I flash the bios on this laptop?
If that computer wont boot to a screen that you can recognize, it is a brick. When the bios is corrupted and it wont allow the machine to start you cannot access any screens that will allow you to recover. It takes special equipment to flash the BIOS when this happens and most places just replace the whole motherboard because this equipment is not used often by repair shops.
Dec 14, 2016 | HP Computers & Internet
Blue screen wont load windows
It might be due to following issues:
Hardware failure
Bad driver
Corrupt file or volume
System misconfiguration
Virus infection
To load windows you need to login via Safe Mode and try these techniques:
Scan your computer with an antivirus
Apply De-fragmentation on your system
Delete all temporary files
Run disc clean up
Fix registry errors
For an instant fix download and install PCFresher to fix this issue instantly.
Apr 23, 2013 | Computers & Internet
@Hotmail.comOk i Have an hp pavillion dv6 and when i turn it on it it loads normally , says microsoft bla bla bla is loading and as it gets to the part where it shows the user log and i gotta enter my...
hi the problem is basically with ur operating system or any previously new software that u might have loaded recently it might have been corrupted if u have tried several times after switching it on and of u should reboot ur laptop 1.step go to the boot menu by pressing F2 at the very beginning when ur system starts and u will see a boot menu will be appeared on the screen in that u will see reset/remove password type ur original password two times as asked to do so and remove it and in the exit tab save changes and exit and see that ur OS loads this time or not
step2.reboot ur system by installing a new OS and u will see a pop up message boot from CD and install a new windows this might solve ur problem if u liked my solution pls rate it
with warm regards- bonefirediv.
Apr 04, 2011 | HP Pavilion dv6000z Notebook
Hello, I have a problem with my laptop which is HP Compaq nx 7010. The problem is the laptop won't open. It only starts until Microsoft loading part and then a blue screen (with many words which I couldn't...
Try to reset bios settings to default. To do this press F10 or other button which allow you to enter bios setup. When you in press F9 or other button which reset bios to default settings
Nov 26, 2009 | HP Compaq nx7010 Notebook
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
The wifi on my hp pavillion notebook dv9000 wont work
Rate this.
May 25, 2009 | HP Pavilion dv9000z Notebook
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Blue Screen trying to load XP on HP pavillion dv4-1125nr
It should have an error code in there somewhere on the screen where it says it's shutting down.
Type that error code into Google and you'll find an array of answers. There's a bunch of things that can cause the problem you listed, but we don't know which one.
Dec 22, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
