Question about New Home Security
I had my electrician install two new Defiant two light motion sensors on a switch. One light will come on and never shut off. Not on test.?????
    Habit-Forming:
    New Friend:
  • 73 Answers
Separate them and change the location where they are positioned.
Posted on Apr 17, 2015
I have a Defiant 180 motion security light that no longer stays on continuous but only blinks when activated.
Your motion sensor lights are supposed to give you a sense of security and peace of mind.
Instead, they're driving you crazy because they won't stop turning on and off, regardless of whether there's an actual intruder setting them off or not.
If your motion sensor lights keep flashing on and off, you should try:
  • Checking whether they're actually flashing on and off or just flickering
  • Adjusting the motion sensor positioning and settings
  • Adding "side blinders" to your sensor
Let's take a closer look at some of the ways you can stop false alarms from your motion detector lights.
If you're not up for any DIY troubleshooting,install the 6ya.com app we will be more then happy to help!!
First off, are they flashing on and off or just "flickering"? If the problem is that your motion sensor lights are flickering, you have a completely different problem than the one we're are talking about in this how to.
Flickering lights (lights that produce unsteady, rapid changes in brightness) are usually caused by one of 3 things:
  • A bad bulb
  • Bad connection between the bulb and the light fixture
  • Problems within the circuit
install the 6ya.com app we will be more then happy to help!! for more help on this problem.
So if you have a motion sensor light that flickers when it's on, we suggest you first try changing out the bulb. If this doesn't fix the problem you'll want to have an electrician check the circuit for bigger problems.
However, if the problem is that your motion sensor lights are false-triggering, continue reading below for some troubleshooting tips.
Adjust the sensor settings Most motion sensor lights have an easily adjustable sensor. This sensor "trips" when it senses a significant change in the level of heat within its vision (that is, an intruder moving within its view).
Now, if the sensor is positioned poorly or if the settings aren't set correctly, it may pick up heat from areas it shouldn't (for example, movement from branches, cars in street, etc.). Use the steps below to make sure your motion lights are positioned and set according to your needs.
Step 1. Move the sensor from "Operational" to "Test" mode. This switch is located on the bottom of the sensor and turns the light off after a few seconds, allowing you to test different settings quickly.
step 2. Make sure that the sensor is directly facing the area you want it to "guard." If you want it to pick up on movement within the driveway, make sure it's tilted down far enough to prevent catching movement from the street but high enough so that it isn't going off when the breeze stirs the flowers lining the driveway.
step 3. You can also check the bottom of your sensor for a "range" dial. This switch dictates the distance that your sensor will detect heat/movement. If it's set to "max", lower the range.
step 4. Adjust any animal immunity sensors. Some motion detectors allow you to choose a pets or animal immunity setting so that the detectors won't trip when pets or animals up to a certain weight pass by. First off, make sure that yours is on if you have pets or animals . Secondly, most pet or animal immunity settings allow you to choose a weight setting. Make sure yours is set to the weight that matches the animals likely to pass by the sensor's field of vision.
5. Reset your sensor to "Operational" mode when done.
If you've played with all of these settings but find that your motion lights are still going off when they shouldn't be, continue on to our next tip.
Try "side blinders" Every motion detector light sensor has a particular angle range. Most angle ranges are anywhere from 180 degrees to 360 degrees.
But sometimes, a sensor's angle range is too wide and is triggered by unnecessary movement, like tree branches swaying.
Try putting thin pieces of electrical tape on one or both sides of your sensors to narrow its field of vision. This can be a "trial and error" process as you experiment with various thickness of tape so be sure to put your sensor in "Test" mode first.
I Hope This Help's We Are Here To Help you!!
Nov 29, 2017 | Home Security
I have a Defiant motion sensor light, model DF 5416 BK A...How do I get it to turn on when only motion is detected?
Try Googling (defiant)(DF 5416 BK A)(manual) without parens to get instructions.
May 04, 2017 | Get Home Security
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
I bought and installed the light below at home depot. It worked for a week. Now it still has power, bulbs work but the motion sensor doesn't activate the lights
Take it back, its faulty.
There is a sensitivity setting somewhere, try moving all the way up and then down a bit.
Dec 13, 2016 | Home Security
All I want is a manual for a Defiant Motion Security light
http://www.homedepot.com/catalog/pdfimages/47/472bbfde-92b4-480d-aa4b-52077755dfb6.pdf
Feb 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Jan 28, 2015 | OUTDOOR Home Security
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Defiant 270 Degree White Replacement Motion Sensor manual
i ave a live switch leg no switch wil sensor function correctly or will it always stay on?
Oct 17, 2013 | Heath Zenith 270 Degree Replacement Motion...
Home Security Logo
178 people viewed this question
Top New Home Security Experts
pawnpower
NOEL
NOEL
Are you a New Home Security Expert? Answer questions, earn points and help others
