Question about Halex Millenia 1.0 Electronic Dart Board
The dartboard has me push start after each persons throw, how can I fix it not to do that?? Want to automatically let the next person throw
How do you import contacts
When you install Outlook 2010, it automatically converts the Personal Address Book that you used in an earlier version of Microsoft Outlook. Outlook 2010 then adds the converted data to your Outlook 2010 Contacts folder.
If Outlook 2010 does not automatically convert your Personal Address Book, you can import your Personal Address Book to Outlook 2010. To do this, follow these steps:
  1. Start Outlook 2010.
  2. Click the File menu.
  3. Click Open, and then click Import. The Import and Export Wizard opens.
  4. Click Import from another program or file, and then click Next.
  5. Click Personal Address Book, and then click Next.
  6. Click Browse, locate the Personal Address Book that you want to import, and then click OK.
    Note Earlier versions of Outlook assign a .pab file name extension to a Personal Address Book. By default, Outlook stores the Personal Address Book in the following folder: C:\Documents and Settings\username\Local Settings\Application Data\Microsoft\Outlook
  7. Click Next.
  8. Click Finish to import the Personal Address Book.
Jul 17, 2014 | Microsoft Outlook 2010
Want to unblock a friend
To unblock someone:
  1. Click 851548_427268774075825_1014901409_n.png in the upper-right corner of your homepage and select How do I stop someone from bothering me?
  2. Click View All Blocked Users.
  3. Click Unblock next to the name of the person you want to unblock.
Note: This will not automatically add the person back to your friends list. If you want to become friends with this person again, you'll need to send them a new friend request.
Apr 01, 2014 | facebook.com
How does an electronic dartboard work?
The playing surface of an electronic dartboard is covered in thousands of tiny holes. Once the dart connects with one of these holes, the score is automatically recorded.
Jul 26, 2012 | Sport & Outdoor - Others
How do i score bowling in a dartboard game
how to play and keep score BOWLING
This dartboard adaptation of bowling
is a real challenge! It is a difficult game
in that you must be very accurate to rack
up a decent score. Player one starts the
game. You must select your “alley” by
either throwing dart or manually pressing
segment of choice. Once alley is selected,
you have 2 remaining darts to throw in
which to score points or “pins.” Each
specific segment in your “alley” is worth a
given pin total:
Segment Score
Double 9 pins
Outer Single 3 pins
Triple 10 pins
Inner Single 7 pins
There are several rules for this game as follows:
1. A perfect game score would be 200 in this version of bowling
2. You cannot hit the same singles segment twice within the same “frame” (round). The
second hit will count as zero points. Hint: Try to hit each single to reach 10 points in
the frame.
3. You can score 20 points per “frame” by hitting the triple segment twice.
4. Hitting the double segment with your second dart will only count as 10 points if you
scored a double on your first throw. Otherwise you will score a total of 9 points by
throwing a double with your second dart.
Mar 03, 2010 | Halex 64339 Match Play Electronic...
Dry want start
you will nead a nother person to help you make this test.first open the dryer door,next put the timer on timed cycle.with your right hand hold in the door switch,next have someone push the start button and at the same time take your left hand and turn the tub clockwise.if it starts than you have a bad moter.the age of the dryer will determin wether it is worth fixing.
Jan 23, 2010 | Whirlpool LER4634J Electric Dryer
I have a 93 ford explorer 4x4 automatic. The 4x4 doesn't engage, or does anything when the button is pushed. Is this something simple to fix? Thanks Duane
This will take two persons to do...with a light hammer or mallet, hit the 4x4 motor on the transfer case as another person is pushing the 4x4 high switch,while the vehicle is in neutral and the emergency brake on, AND FOOT ON THE BRAKE.BE CARFUL NOT TO RUN OVER YOUR HELPER!!!! If it starts to work,replace the 4x4 motor. The inside of the motor gets corrodid from water and dirt.
Nov 14, 2009 | 1993 Ford Explorer Limited
How do I make a conference call
first you have to have a person that you want in your contacts. then click on it and push the green botton. if in the option you didn't activet automatic video, push the botton when you connect to start the video .
Good luck
Oct 04, 2009 | Skype IM
Halex Millenia 1.0 Electronic Dart Board Logo
560 people viewed this question
Top Halex Sport & Outdoor - Others Experts
Are you a Halex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
