Question about Canon P23-Dhv G Printing Calculator
I purchased 2 of the exact same calculators and set them up at the same time. one prints in blue & red...the other one prints only in blue. How do I get it to print in the 2 colours?
    Top Expert:
  • Canon Master
  • 6,702 Answers
Perhaps you need a 2 coloured ribbon in both?
Perhaps setting them up in the same time was not a guarantee you have the same settings in both? check the manual to see how you can activate and use both colours.
Posted on Apr 17, 2015
Casio ms-20nc set tax rate
Non-printing models MS-20NC (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models MS-20NC (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Apr 29, 2014 | Sharp EL-330AB Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2¼-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
I need the instructions for a canon P23-DH V calculator
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Apr 16, 2010 | Canon P23-DH Calculator
Canon P170-DH
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Jan 10, 2009 | Canon P170-DH Calculator
Color of ink
The resolutions for this is usually removing the piece of foam packing material in the printing area.
Apr 28, 2008 | Canon P23-DH Calculator
PRINT COLOR
Hi...it appears that the ribbon is on upside down..The black has to be on the top and the red on the bottom. Just switch spools and turn the ribbon over..either that or there is a spring off the ribbon platform solenoid on the right side of the printer just below where the ribbon comes off the spool. If the spring is off or broken the ribbon platform will rise too high and print in red. Remotely the solenoid (little blue thing) could be bad or out of adjustment.
Hope this helps..this is usually all it can be.
Squipps
Nov 27, 2007 | Sharp EL-1750PIII Calculator
TI-89 Problems
There isn't anything "wrong" with it.
Go to mode, and set the results of your inquiries from Exact to approx.
If you put in cos(e^2), it will print out cos(e^2) because it's the most exact it can be without going into a decimal. (cos(e^2) will be a transcendental number like Pi).
Sep 09, 2007 | Texas Instruments TI-89 Calculator
How do you set the tax rate?
press AC press and hold set key for2 seconds, until zero appears on the screen press tax+ input tax rate press set check by pressing AC, then pressing tax+ key. It should be the tax rate you inputed.
Aug 18, 2007 | Casio DF-120TV Calculator
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
Canon P23-Dhv G Printing Calculator Logo
80 people viewed this question
old marine
old marine
