Question about Kitchen Ranges
Oven & Broiler quit working on same day.
The stove top burners work fine. The control panel allows me to set an oven temp & shows that it is preheating, but no flame in the oven. The oven & broiler both fail to light. The igniters do not appear to get hot. If either one would lite then I would just replace the other igniter, but for them both to quit working on the same day leads me to believe that something else might be wrong. Could it be an electrical issue of sending power to the igniters? Thanks-Jason
  • 2,210 Answers
Yes, I think you have the answer. If you have the knowledge, check the electrical supply side, fuse etc. Check out your user manual in the fault finding section. The oven has a thermo switch that prevents the gas opening if theres no ignition.
Posted on Apr 17, 2015
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Kenmore elite stove model #7909912949B. Can get anything to work on oven. Light comes one. Nothing else in the enter panel. Top burners work.
Can you enter the oven temp and press start on the control panel? Do you hear it click on, but it just does not get hot? Try turning on the broiler and see if the broiler gets hot.
Feb 01, 2015 | Kenmore Kitchen Ranges
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
Jul 01, 2010 | Ovens
Oven/Broiler doesn't work. Stove top works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
I have a GE Model JGBP265BEA1WH and the oven would not work. The broiler & stove top did. I replaced the ignitor and now both the oven and broiler do not work but the burners do. I tried to locate the...
The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
Jan 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
