SOURCE: 1993 nissan 240sx clutch problems
Did you bleed the system fully after changing the cylinders? Those are the two main components that cause such problems. If you bled the system out, and it still has the problem, then you most likely have a ruptured line somewhere that is allowing air into the system.
SOURCE: Stuck in 5th gear
That just recently happened to me. If your stick wont move into any of the gears, then you need a clutch. But if you can shift into the gears but dont go anywhere, then you need a new transmission.
SOURCE: gearbox spinning,with clutch depressed,gearbox crunching.
needs a new clutch ,pressure plate dragging caused by worn springs
SOURCE: spider gears fell on rear differential 95 ford explorer
It's not easy to put them back, but if you get the side gears in position with the axles bumped out as far as you can, the smaller spider gears can be "walked" into place. Try having your buddy rotate one of the wheels slowly until each one fits in. It's tricky but you'll get it.
