Question about Karcher Garden
I have a karcher power washer and every time I use it my power is tripped bought it brand new a bout 2 years ago not really had the use of it
Use a tumble dryer off the same socket in garage not at same time though
  • 2,210 Answers
You don't say if its 240 or 110 volts. Tumble dryers take a huge amount of power and can make the socket quite hot. Turn off the power and see if the socket is damaged. Try the washer somewhere else and see what happens. Try it at a friends house? Determine if its a house or machine problem but washers do have a big start up surge. Get an electrician to look at the supply and machine.
Posted on Apr 17, 2015
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
My karcher washer has lost most of its pressure it doesn't clean the bricks like it used to
The lance hose that attaches to the pressure washer keeps coming off when the power to the machine is turned on, i've only used this product four times since new in January this year.
Sep 06, 2010 | Karcher K2.26 Electric Power Washer
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K2.94 Overheats
Well, there is a switch inside. It is controlled by the valve that allows the pump to go into bypass when you let go of the trigger. This switch may be worn out or the valve that controls it is sticking. It may also be that your motor is just worn out. There is a heat sensor inside the motor (you cannot get to it) that sometimes wears out and trips too easily.
Jun 12, 2009 | Karcher K2.26 Electric Power Washer
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
111 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
