Question about Pool & Spa
The time keeps changing by itself causing issues
My05 Chevy Silverado 2500 keeps popping itself into 4 x 4 I've change the oil in the transfer case and its didn't seem to help
I'd check transmission and transfer case linkage systems. Out of adjustment linkage and bushings of said linkage can cause strange behavior. The shift lever/s may have similar issues with their pivots if they are "sloppy".
Apr 15, 2015 | Cars & Trucks
It doesn't matter if it is on lp or electric turns on and off randomly. sometimes it says on for a couple hrs other times keeps going on and off. the light inside also goes off
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Mar 11, 2015 | Refrigerators
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
Changing channels
A common issue with this model is the control key board (the key input board that has the buttons on the cabinet of the TV).
This board can cause a lot of issue ,from changing channels by itself,to intermittent shut off, also sources cannot be switched or they switch by themselves.
The less common issues would be the remote eye or the main board.
If you give the full model number and the product code from your TV, I can give you the part numbers.
Apr 01, 2010 | LG 22LG30 22 in. LCD HDTV
The car keeps stalling after I changed the battery. I changed the battery on my 2003 Camry and now the engine keeps stalling. I was told it would improve with driving but it's not getting better. A...
If the car ran well before the battery change I'd say there is an issue with either the battery or the installation. Check the leads be ceratin the connections are clean and tight. Examine the cable too' did one get split and is now causing a poor connection. I have never heard of a new battery causing issues and being told it will get better with time.
I'd take a good look at the install or the battery itself.
I hope this may have helped,
Tom
Oct 02, 2009 | 2000 Toyota Camry
2Wire router keeps dropping connection
if you try to change the router and getting same problem, i think you need to isolate it first without the router because this is not the issue, by the way did you ask your ISP to run a line test? what is the result? have you try to change the modem? my first suspect is the modem.
Nov 09, 2008 | 2wire (1000-400108-001) Router
Radio problems
body control module has been known to cause this
Jun 08, 2008 | 2005 Chevrolet Tahoe
NAD T753 5.1 Channels Receiver Problem
It could be a heat issue, is the receiver able to get air to cool itself? Also, a bad speaker or mismatched speaker may cause this. Sometimes hooking up extra speakers may cause this. Other than that, it would be a service issue.
Geno
Mar 05, 2008 | NAD T753 Receiver
Screen keeps changing views
it think maybe you're infected with virus, or your monitor itself have problem.try to contact an expert technician of monitor.
Jan 14, 2008 | Gateway FPD2275W LCD Monitor
Pool & Spa Logo
52 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
