Question about Radio Communications
How do you change the rods?
Don't want to break it, just got it.
    Problem Solver:
  • 43 Answers
A bit more info is required.
Posted on May 17, 2015
  • 4 Answers
Change the rods... On what?
Posted on Apr 29, 2015
How to change shift rod on a harley dayna
If you need to change the shift rod and pawl assembly you need to pull the primary, pull the transmission cassette and then you cab get at it and replace it. The weld seems to break often on these parts,
Jan 13, 2014 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
My MYD edger breaks off the adjustment rod any fixes
I've broken two of them. I had a lot of vibration, and the blade was bent. I'm replacing the rod and the blade to hopefully fix the problem. If it breaks again, and I still have the vibration, I'll look at replacing the belt and possibly the pulleys.
Feb 10, 2013 | Mtd Garden
Change break pads 2003 harley davidson v-rod
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Harley rod Front Brake Pads avi
Jun 26, 2012 | 2003 Harley Davidson VRSCA V-Rod
How to change brake light bushing on 1998 nissan frontier
the break light switch has a needle like rod that pushes up against a flat plastic bushing. The bushing has probably fallen out. Without the bushing the rod has nothing to push against. So, your brake light stays on. I replaced mine with a rubber press screw that fits perfectly in the small hole. Rubber press screws are generally used to secure rubber splash guards under vehicles. They push in and don't back out. Now reattach your break light switch and the rod will now have a bushing to push against.
May 07, 2012 | 1998 Nissan Frontier
How do I adjust emergency brake on 1990 ford f 350 dually
Under the cab on the drivers side about even with the door hinge the cable splits for the two different sides, right in this junction is an adjustment rod in the cdables connecter. If all things are the same and the brake is'nt tight enought to hold the truck don't adjustr any hting till you check the rear brakes as your describing the brake shoes worn out and even groung into the drums. The cables only need to be adjusted as the cables are removed or changed and once adjusted are good to go. The rear break shoes can be OK but thier adjustment to be as close to the break drums as possible with the shoes adjusters. You can get into the back of the drum though the adjustment hole but some don't have the hole and the drum will need to be removed. If you have this problem the brakes need to be looked at anyway and worn parts changed to new as failure altogether cvan cause a crash.
Jun 24, 2011 | 1990 Ford F350
I CANGED THE OIL IN MY 1998 SUZUKI AND SMOKE AND OIL COME OUT THE TAIL PIPE WHAT COULD BE THE PROBLEM
Sounds to me as if you put to much oil in it, don't run it this way or you will bend a rod or break a piston.
Apr 30, 2011 | 1998 Suzuki VZ 800 Marauder
How do you change the inner tie rod and do you need a special tool or no
yes you need a tie rod end socket tool, this breaks the tie rod ball socket loose without damge to the grease boot.
Feb 23, 2010 | 1991 Chevrolet Lumina Apv
How to change left front tie rod on nissan quest
Loosen the wheel lugs, jack up the vehile,use jack stands under the frame for safety, remove the tire.Turn the steering wheel hard right.Now I am assuming you want to change the outer tie rod on the steering rod.Or maybe the inner.
Then loosen the nut and bring the nut up to be flush with the tie rod joint.
Now either with a splitting tie rod fork (you can rent one from a local parts store free) hammer it tight between the ball part of the joint and the tie rod, it should pop off from the taper lock.
If not give a few sharp raps with good sized hammer and will break it loose.
You can get a manual from your local library on the vehile to help .
Oct 24, 2009 | 2004 Nissan Quest
I have a Ford Windstar van and we had the scope done on it the code came up 1518 I was wondering what that code ment
.1518 / INTAKE RUNNER CONTROLL FAULT Look at the rods where they attach there is a plastic bushing holding the rod fast. These plastic clips tend to break. If it breaks the rod will fall off and create the code you have. If the rods are attached check the lines to the actautors that the rods attach to and make sure there are no breaks in them. If there is a break you can fix it by installing vacuum hose between the broken peices.
Sep 13, 2009 | 2002 Ford Windstar Cargo
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Generic problem for all Vacuums
Posted by andy78billy on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Radio Communications Logo
273 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
