Question about Karcher Garden
Every time I set it up and use I trips my power
I have a Husqvarna extractor fans, the type with the motor on the roof. In seems to work fine on full power but not no the lower power settings. It also trips out when the light and extractor are on at...
The 'trip out' is where the unit draws more power than the breaker is rated for. Because it runs ok on full power (check they are running at full speed on this setting), the breaker is allowing enough power to reach the unit in this setting, so the breaker is fine. However when you switch on the light with the extractor it trips, at that point it is drawing too much power through the breaker at it trips to stop the device burning out. Check the connections to the unit are clean and dry and firmly made, if not power could leak away drawing more from the breaker. The next step is to measure how much power is being drawn by the unit in each mode, using an Ammeter in line with it. If you do not know how to do this (its dangerous if you get it wrong) ask an electrician to check the current draw in all modes.
Dec 19, 2013 | Garden
DSP A 1092 keeps tripping when switched
try unplugging each set of leads 1 set at a time,and after each set of leads are unplugged switch it on as it may be a set of faulty leads,it sounds like the safety cut out is coming on and switching off the power to save your system blowing due to bad or broken phono leads or speaker cables.it could also be that you could have blown your output transisters or something else thats causing the saftey cut out to cut off the power,also make sure there are no loose connections inside your mains plug as this would cause the same thing.
Jan 06, 2013 | Audio Players & Recorders
Timer stops at on and off trips and doesn't turn on or off
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
Jun 23, 2010 | Intermatic Malibu 300W Power Pack...
How to set the clock for a Hyundai Getz?
hi from uk ! to set clock/time on getz look t the speedometer ? you will see two buttons on the bottom of dial ? the left button is to cancel the trip meter by pressing button in for trip A and again for B trips the right hand button marked hr + min ? to set hour time turn to left untill hr time is shown then release now turn button to right to set the minutes then releas when time/minutes ar correct that is it! ps you cannot cancel the odometer/milage clock only trip meter hope this helps best wishes from n/west uk
Oct 16, 2009 | 2001 Hyundai Sonata
T101 Intermatic Timer will not turn lights on or off
You have a weak timer motor. The T101 is notorious for it. I have 6 on my property and have had that problem numerous times. You need to replace the guts of the timer.
Jul 05, 2009 | Hardware & Accessories
Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Apr 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
No power to the fuel pump in a 1987 ford tempo
Did you check for a trip switch in the trunk behind panel at the side, probably on driver side? Little plastic box with a plunger looking thing sticking up. Push plunger down, to make sure it's set, in case it tripped. They used to trip all the time, if you just banged that fender area with your hand.
Dec 21, 2008 | 1987 Ford Tempo
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Garden Logo
41 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
