Question about Dryers
The start button starts the process but wont stay latched on. it works fine but I would need to stand with my finger on the button for some time and then it will stay on. what's wrong please
  • Dryers Master
  • 5,323 Answers
Sounds like u have a bad push start button , test with a meter for ohms?
Posted on May 04, 2015
I have a Sears Kenmore elite model# 11072942100 that will not always stay running when pushing the start button, however if I hold down the start button and then turn the dial it will eventually stay
Rick,
Good call on the timer switch. If the teeth have worn at the start position, starting would be delayed until the timer is rotated beyond the worn area. The normal operation of the start button is that it should to be pushed in and held for a second, to prevent inadvertent starts.The problem could be related to the door latch. The door safety switch will make intermittent contact if the door is not completely latched. If the door has become misaligned from downward pressure, it may not be drawing the door in enough to push in the switch. First check the alignment of the door. If the door is low, try bending the hinges back up. Open the door just enough to get your fingers inside the bottom of the door and slowly pull up. If the door is better aligned it may push the switch in better. Close the door and try the dryer.Next try holding the door in with one hand and pressing the start button. If the dryer starts every time while pushing the door in, then the latch is worn and should be replaced. I hope this solves the problem.
Good luck
Nov 29, 2014 | Kenmore Dryers
Door latch stays down and will not allow the door to close
sound like the litle robe on the door latch has stretched
Feb 05, 2014 | Whirlpool Dishwashers
When I take my finger off the start button the saw stops
most prob in start stop switch..called a latch but with out any info on type/make/mdl, impossible to confirm.
Dec 31, 2013 | Saws
Release cable clicks, but hood wont rise high
Tap on hood should pop up, then lube latch.
Dec 11, 2009 | 1999 Chevrolet Tahoe
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryer problem
with power disconnected
follow the wires from the start button, to a relay,
check the wires (both ends) of all leads to the relay and reconnect any that have fallen off. (crimp tighter if they have fallen)
Check door switch function and connection.
check timer connections
the relay start-button timer and door switch comprise a latching circuit, when the start button is pressed the relay is supposed to latch closed and supply current to heater and motor. if the latching circuit disconnects the relay does not latch closed, and only runs as long as the start button is pressed.
if nothing has disconnected one side of the relay has usually failed, and the connection is not being made to latch the circuit
replace relay
cd48320.jpg relay is shown at right, 2 switches connected by a dashed line.
Oct 12, 2008 | Kenmore 62602 Electric Dryer
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Press start button but wont stay on
the switch is fine
the switch in all dryers triggers a relay, that then latches and supplies current to motor and heater, until deactivated by door switch or timer switch
inside the control panel,
trace the wires from the start switch to the first device
c27eaf9.jpgmay be opaque.
ensure that the wires are all connected.
if all are connected replace relay
the local part store will have the relay it is common to most dryers
Cant give exact instructions, no experience with particular model
Aug 06, 2008 | Tricity Bendix TM310W Electric Dryer
Self clean will not start
e1 f5 is saying your door latch is not operating will either be the switch or the latch motor or the latch itsself is out of line and not going into the slot to latch the door depress the door switch then do clean keeping your fnger on the door switch at all times observe if the latch comes out or not if it does its out of line if not its the motor or the switch still keeping your finger on the switch hit cancel
Dec 28, 2007 | Kenmore 72012 / 72014 Kitchen Range
Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
Dec 27, 2006 | Whirlpool 24 in. GU2500 XTP Built-in...
Dryers Logo
59 people viewed this question
Top Dryers Experts
