Question about ASUS Computers & Internet
How to activate closed captioning - ASUS Computers & Internet
  • ASUS Master
  • 3,287 Answers
Closed captioning for video files will either be hard coded into the video - meaning you cant turn off or change the language; or have an accompanying file of the same name - but an .srt extension.
Example: The movie "Gone With The Wind" will consist of the movie (video and audio) file called:
Gone With The Wind.avi or Gone With The Wind.mp4;
plus, a closed caption file called:
Gone With The Wind.srt.
If the video player you're using supports CC, such as "Videolan" "Media Player Plus" or others, it will automatically detect and play the CC .srt file ONLY IF it is located in the same directory as the movie file (.avi, .mp4). If you do not wish to see the CC on screen, simply delete or move the .srt file into a different directory.
If you're trying to display CC when playing a purchased or rented DVD or BluRay disk, you'll need to access the menu of the player that you're using to locate the options. Look for language / CC settings and make the desired choice.
Posted on Apr 17, 2015
Trying to get closed caption on my firestick. Directions say run movie then press menue nothing happens! Where is menue on firestick?
To activate your closed captions, start by clicking the center button on your Amazon remote to launch your player controls bar.
Simply click on the CC icon to activate or deactivate closed captions.
Sep 11, 2017 | Televison & Video
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How to activate close captioning?
There will be a button on the remote control; marked "CC". Press it once, will activate Close Captioning, and an other press to it, will deactivate. This button is a toggle type.
Gopakumar Gopalan Google
Aug 14, 2014 | Televison & Video
I can not turn the captions off on my magnovox television
It sounds as if you have the closed caption option activated on your TV. The easiest way to disable this is to search your remote for the closed caption button. It is most likely the button marked CC or Closed Caption. Good Luck
Jan 11, 2011 | Philips Magnavox 27MS343S 27" TV
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Closed caption on. Want it off.
the closed captioned in stuck in spanish on the screen does not move how do we remove this.
Jan 21, 2009 | RCA RCU4GLW Remote Control
Closed caption
You have to activate the closed caption option on your charter cable box. Power off your cable box and immediately push the menu button. A menu should appear where you can toggle captioning on/off. Good luck!
Oct 27, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Computers & Internet Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
