Question about PfaFF Sewing Machines
Why is my pfaff stop sewing and then starts again after tap on right side?
  • 86 Answers
This generally indicates an electrical or electronic short, either of which should only be approached by a trained technician. However, it is often hard for technicians to find intermittent errors, so, you may have to wait until it happens so often that it won't be missed. Sorry, wish I had better news.
Posted on Apr 18, 2015
My Pfaff hobbylock 786 stopped working, it is pulling very very slow, nothing is stuck, could it be the footpedal
Most likely is old dry oil that is sticking things together. Avoid trying to run the machine until it gets addressed as continued use may damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Feb 01, 2018 | PfaFF Sewing Machines
Pfaff 7570 .. press foot to start...starts forward slowly ...will not stop without switching off power will not change speed ...will not select stitches
There could be several things going on with your machine, but once you take care of cleaning and oiling, you will be able to narrow down the other(s). Refrain from trying to run the machine as the drag on the motor in attempting to move the stuck parts could damage the motor.
Sep 17, 2017 | PfaFF Sewing Machines
My Pfaff 1222 will not sew; the needle moves up and down in the same hole. What does it need to fix this problem?
More than likely, the machine is seizing due to old oil that has dried out--probably affecting the movement of the feed dogs. As a mechanical machine, it needs frequent oiling and cleaning to keep it operating smoothly. Most older machines, like this, are set aside or abandoned for this very reason. If only their owners knew there is a very simple solution. They can be rejuvenated with some elbow grease, "good" sewing machine oil, and heat. Below is the method I've used to find a second life for several older machines:
Your machine may be purring again in no time!
FWIW--your machine is popular and well-worth spending a little time and money to make her hum again:
Thread Pfaff 1222 Vs New Machine
Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiSvKLPwNHTAhWmr1QKHQjLDYQQFgg7MAM&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fpfaff_1221_1222-manual-EN.pdf&usg=AFQjCNEOGguC-PcdLTPymc0oWxgw7Utvkw&cad=rja
May 02, 2017 | PfaFF Sewing Machines
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
What is the problem with my Pfaff 1200, it sews a little and stops. When I turn the weel it sews a little and stops again
The machine can gum up when the light machine oil evaporates.
Ask the shop that did your last Service.
Feb 14, 2015 | PfaFF Sewing Machines
Last year I changed the machine engine (PfaFF 1222 E). I noticed immediately that the machine sewed too slow and I thought it was a problem of the kind of engine the repairer had put into the machine. But...
If the machine did sew fast the the replacement motor, then the problem might be that the machine is getting gummed up somewhere. Pull off the top cover, remove the 5 screws from the bottom of the base plate, (4 large screws, 1 small screw), remove the base plate remove the 1 screw from the bottom of the free arm cover. Now you can see most of the moving parts. Spray a little WD 40 on all the areas that you see metal to metal rubbing together, both on the bottom side of the machine and the top side. Don't flood the machine and stay away from the motor area. Plug the machine in, lay it on it's back and run it full speed, or at least till it runs full speed. After you free it up, blow out the machine with compressed air, and reoil with tri flow all the areas again. Run the machine again, and you've started your own tail gate repair shop.
May 05, 2011 | PfaFF Sewing Machines
I think I need a power board because my machine keeps stopping. Have to wait to start again. Also my light is broke. I have a 1171 and wondered if parts are still available for that machine. It was my moms...
Hi, ..go for the simple first. It could be motor brushes..the next time the machine stops try turning the handwheel and see if it starts to run again. If it does, the motor brushes are worn down. It would probably be less than a 100.00 to repair it.
Good Luck!
May 07, 2010 | PfaFF Tiptronic 2030
My pfaff hobbymatic has stopped doing zigzag and the needle is stuck on the right hand side
Check your needle position selector, it must be selected to the right position for special application. Default must be in the center position. If it doesn't want to center itself when straight stitch is selected then I would thing a link inside came loose and a repair person should assess your problem specially if having no experience working on them.
Apr 22, 2009 | PfaFF Sewing Machines
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
63 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
