Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is showing error code F-70
When I move the washer out to service it and remove and reinstall the electric plug, it works. I have checked the level in both places and they appear to be the same.
Cn0 fault code is due to no communication between the user board and the CCU. Look for a 3 blue wire connections and crimp the white Molex conneactor. If that doesn't work replace the wire connector.
Posted on Apr 17, 2015
  • 171 Answers
Fault 70 indicate bad connection on ccu control unit.
Unplug power before opening the lid
Mhwe300vw11 error code f 70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa
Oct 09, 2011 | Maytag MHWE300VW Washer
My kenmore elite washer has a F 70 displayed? Wha...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore ELITE HE 5t 47086 frontload errror code F70
Feb 26, 2010 | Kenmore Elite 45986 Front Load Washer
Error code f21, and the door stays locked
Error Code F21 = LONG DRAIN
Most probable cause is a foreign object blocking the filter. Remove the lower front panel. The filter is located in between the pump and tub. remove the filter and clean out foreign material (socks, coins, nails ect..) and reinstall If not check the following items
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E 70 error message
Sep 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer has displayed f 70 error code. what does this mean
Aug 15, 2009 | Kenmore Washing Machines
What is "F" code 70?
Jun 30, 2009 | Kenmore Washing Machines
We have a whirlpool duet clothwasher giving us a f 70 fault what does this mean
Jun 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite quiet pack washer quit. Please help!
Feb 18, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
