Question about Ed Hardy Bandit Dragon Stainless Steel 316L BNDR Watch for Men
HAVE LOST THE CATCH That holds the strap together looking to get a new one
How do I change the watch strap?
There are typically small pins that hold the band together. There is a special tool to use on metal watches that can be bought
Jul 29, 2014 | Klaus Kobec Womens Couture Leather Watch...
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
I need a new watch strap for my Nike Hammer WC0021 sports watch. I have lost the pin (43mm in length) and the metal rectangular bar from the end of the strap (hence it cannot stay on my wrist) but I...
mcdevito75 here, Best bet, look for a small watch repair shop in your area, they should have replacement pins. Approx. $5.00 maybe even less John you can also type into serach, Contact Nike Hammer Watch.com Nike has to have a web site.
Feb 09, 2011 | Nike WC0021 001 Mettle Hammer watch
My DKYN is a ladies large D shape stainless steel case quartz. White leather strap. I have lost the tiny pin head that holds the strap pin in any suggestions please
sounds like a broken spring bar.They break all the time and can be replaced by any good jewellery store while you wait.
Aug 17, 2010 | Watches
Watch strap that holds face of watch separates and face falls off
mcdevito75 here, Besides online with Timex for another original strap, you can also look for a small watch repair shop in your area for a replacement strap.
Jul 05, 2010 | Timex Ironman Triathlon 50 Lap Digital...
The strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Aug 14, 2009 | Casio Watches
How to change battery in Casio wave ceptor4305
If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
After battery replacement, just push the contact back into place till it fixes.
If there are screws holding the contact, just undo them.
Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
Sep 12, 2007 | Field and Stream F25SLUMI Wrist Watch
Broken strap.
contact Cartier. www.cartier.com Donald
May 20, 2007 | Cartier Santos W20056D6 Wrist Watch
Ed Hardy Bandit Dragon Stainless Steel 316L BNDR Watch for Men Logo
16 people viewed this question
Top Ed Hardy Watches Experts
ray gallant
Buddy lotter
Buddy lotter
Are you an Ed Hardy Watch Expert? Answer questions, earn points and help others
