Question about Water Water Heaters
I have a ideal combi boiler 24kw radiators is working but no hot water
  • 17 Answers
SOURCE: COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Posted on Nov 27, 2008
  • 150 Answers
SOURCE: combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Posted on May 03, 2009
farfield
  • 462 Answers
SOURCE: not continuous hot water and radiators
If it has a distance from the boiler to your use the water in the lines and the lines themselves ahve to warm up before you will get hot water, Let me know more if this dosnt help. Please rate me as high as possible if it does help you understand your trouble.
Posted on Jun 02, 2009
gary1121
  • 332 Answers
SOURCE: vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Posted on Jun 06, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Worcester 350 combi boiler on but water cold and radiators cold. Have put pressure up but made no difference. What's wrong with it?
If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
Feb 06, 2015 | Water Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Sep 11, 2009 | Water Heaters
Combi boiler problem
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Nov 13, 2008 | Water Heaters
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
vince
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
