I have a affinity front load washer first it said code CD now it is e23 it won't spin or wash what does this mean?
  • 575 Answers
Http://www.repairclinic.com/PartDetail/Drain-Pump/137221600/2754548
Basically the pump gets restricted and the washer shuts down. It can be found at the bottom of the washer with 2 hoses.
Posted on Apr 17, 2015
  • 1314 Answers
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at b4829@yahoo.com for futher info
Posted on Jul 10, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 1382 Answers
SOURCE: What does the code E10 mean? The washer flashes
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Posted on Jun 28, 2010
  • 3 Answers
SOURCE: what is error code E23 for the Frigidaire Affinty
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Posted on Jul 25, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
I have an Affinity washing machine that shows an E23 error code.
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Sep 11, 2014 | Frigidaire ATF6000ES Front Load Washer
What does error code E23 on a frigidaire affinty front load washing machine mean
Good Morning Friend,
I understand you are receiving an E23 code on your Frigidaire Affinity washer, model# GLTF2940ES. The E23 code states that the drain pump relay on the control board has failed. This could also be a possible false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
Code E23 comes up om my Frigidaire Affinity front load washer. I have changed the motor control board but still have the code E23, checked the wiring harness and everything looks good. Unplugged the pump...
Hi James, thank you for your post! If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. However, since you have already replace the control board, one of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker. It is important to wait roughly ten minutes and then turn the washer on. If the error code persists, it would be advisable to reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 07, 2013 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
We have an Affinity ATF6000F washing machine that makes s horrible noise during the spin cycle and shuts off with water still in the basin. When we hit Start and Cancel at the same time we get code E23.
The error E23 denotes the drain **** relay on control board is failed.
Check whether there is some lose connections in the wires if nothing lose connection is there then you need to replace the control board.
Thank You
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
Thank you !!
Jun 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Started out with E20. Now E23.
According to the code, the board is the culprit. The pump should be 120 V. Why don't you take a cheater cord with some alligator clips and put power directly to the pump. If the unit drains, you can pretty much trust the code and replace the board. Catriver
Nov 04, 2008 | Frigidaire Affinity Glacier Blue 3.5 Cu....
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
