Water is not going into washer. Staying in filter
  • Washing Mach... Master
  • 2,160 Answers
Is the filter clogged?
Posted on Apr 17, 2015
Washer doesn't stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Kenmore Washing Machines
No, problem just a question?.....I just purchased a Maytag washer machine, and I want 2 know can U use your old water hoe (kenmore brand) on a new Maytag washer machine?
You should be able to. Check the ends going into the washing machine for plastic screens. They may need cleaning, if calcified from hard water use some vinegar and it will dissolve the calcium.
If you go to Sears or any appliance store, they sell all brands of Washers and usually have only 1 water hookup prepackaged. Staying with the same brand should insure no problems.
Dec 02, 2010 | Maytag MVWB300W Top Load Washer
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Is there a filter that can be gotten at to clean? Reason -- very stale water smells are staying in the laundry now. Thanks for your help! ~~Canadian Query
I would try to run a cycle with a very strong clorox solution through your washer. It may be the easiest way to fix that.
Nov 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Water not staying in basin for wash
The drain hose must go above the highest point of water in the tub before entering the drain or it will siphon out. Add pipe to get above the top of the washer or add hose and raise it up.Make sure there is a air break between the hose end and the trap or it will be all for not. Eric
Aug 12, 2009 | Washing Machines
Water left over after i finish laundry.
IT IS USUAL BUT YOU CAN DECREAS THIS PROBLEM BY :
1- PERIODICLY SAY EVERY 30 DAYS USE LONG PROGRAM WITH 95 DEGREE CENTIGRAD WITHOUT CLOTHES AND WITHOUT SOAP UNTILL FINISH THE PROGRAM
2-YOU CAN DRAIN ALSO THE RESEDUAL WATER THROU OPEN SLIGHTLY THE DRAIN FILTER AND THE WATER COME OUT FROM ASMALL HOSE BESIDE DRAIN FILTER (THIS HOSE HAS CAP)
DO NOT FOGET TO TIGHT THE DRAIN FILTER
Jun 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Whirlpool LSR6132EQ1 Washer - Doesn't Rinse
I'm having the same problem with mine, but it's staying hot instead of cold. I've been reading about it, and it could be a kink in one of the water hoses (simple fix). The filter where the water comes in at could be clogged. The water inlet valve could be bad (which I'm thinking this is what is wrong with mine). This post is old, but just in case someone else is looking for this info... From website: http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
Jan 09, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
