Question about HP Office Equipment & Supplies
I have hp 9500 but it show me 50.6 fuser erro I change the fuser it still the same
  • HP Master
  • 3,957 Answers
Please read through these troubleshooting steps and suggested repairs: http://www.laserquipt.com/support/idx/46/292/article/-50x-Errors.html
Posted on Apr 17, 2015
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
SOURCE: HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Posted on Jul 07, 2008
  • 37 Answers
SOURCE: laserjet 3550
Yes they will
Posted on Dec 09, 2009
  • 16 Answers
SOURCE: hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Posted on Mar 02, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have a 50.2 fuser erro on our Color Printer HP
The 50.2 code on nearly all HP laser based machines including your 4700 means you have a fuser error. The fuser unit is the assembly that heats up and "fuses" the toner onto the paper. There are a few things you can try including, power cycle the printer and see whether the code resets or try reseating the Fuser Unit. Neither of these will resolve the issue in most cases. Most of the time fuser unit replacement is necessary.
Here is a link for you to see pricing and a picture for your fuser unit. You may want to just buy your own fuser and replace it if your are mechanically inclined. If not you can have a local printer repair shop replace it for you. At least they won't rip you off on the price of the fuser unit. Note that there may be some cheaper prices out there on this unit.
http://www.precisionroller.com/search.php?q=hp+4700+fuser
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 23, 2010
Getting a 50.6 FUSER ERROR on a HP color Laserjet 9500 printer. I bought the image fuser kit and replaced it. Still getting the error. Suggestions?
check the connector that the fuser connects to for damage. If the plug is intact you will probably need to replace the power supply (Low Voltage PS) C8546-69003 is the part number
on a unit of this vintage the part won't be cheap. A quick search on the net shows it from $350 - $600
Good luck
Dec 04, 2015 | HP LaserJet 9500n Printer
50.1fuser erro hp5550dn
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
Oct 02, 2013 | HP LaserJet 5550 Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
Shows 50 service in printer window
ok its either going to be your psu unit or your fuser.... if its showing the 50 service and doesn't print anything I would definitely replace the fuser... here is a link with some more information on the matter... http://www.fixyourownprinter.com/kits/hp/K05
Jan 06, 2010 | HP LaserJet 4 plus Printer
HP2605 shows 50.7 erro
Sounds like a faulty sensor. Buy a can of compressed air blow it throughout the printer. Sometimes toner dust sits on the sensors giving a false reading. If after this you still get an error you're going to need a printer engineer!
Dec 15, 2009 | HP Laserjet 2605 Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
Mar 23, 2009 | HP Color LaserJet 3500 Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
Apr 03, 2008 | HP LaserJet 9500n Printer
Hp 4250 paper jam erro
Feb 12, 2008 | HP LaserJet 4250dtn Printer
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
