Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
HOW FAR CAN THE PEDESTAL STAND 'SWIVEL'? I CAN GET ABOUT 15 DEGREES EITHER WAY - IS THIS THE LIMIT OR CAN I ADJUST TO INCREASEDEGREE OF 'SWIVEL'?
  • Anonymous Apr 18, 2015
    Thanks Joe
    Habit-Forming:
  • 146 Answers
I believe this is the limit, physically altering the engineered base for this television may put it in danger of falling or breaking. It's a 40 inch LED TV and really not that heavy, perhaps you could look for a lazy Suzann type of base that you could put beneath the TV to give you more extreme swivel capability.
Posted on Apr 18, 2015
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
Vizio base stand model vx37l
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
www.back2lifeelectronics.com
Jan 10, 2013 | Vizio VX37L Television
Separating a glass tv pedestal from a glass tv cabinet
I can only figure that the cabinet is Not part of the TV's normal design and it has been just sitting on this cabinet for a long while?
If this is so then it has by weight and heat sweated itself onto the top, synthetic feet are made of complex materials including oils which get exuded then form a quite powerful glue action, also that spray polish has baulking agents to make it look good in use these act as glue.
If this top is glass then its pretty well resistent to most things, try windolene glass spray its safe and dissolves many things on glass as a cleaner (or other surfaces). Move up to say WD40 a mineral oil again safe wipe clean with meths spirit to clean up just add in a bit of tilting to break that grip.
Hope this helps......
Jun 27, 2017 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
Jan 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Hi, We can not get our TV to swivel. What to we
U have to litterly turn the tv 20 degrees to the left or to the right.If u wanted the tv move to the left or the tv move to the right.The base stand dose not move,it is a solid base stand to hold the tv in with screws.Some tv u can swivels,but only can do it up and down by 20 degrees screen base swivels that it.Take a hold tight of the LCD screen panel and push it up or down 20 degree,that is ur base swivels.
Nov 15, 2010 | LG 37LG30 37 in. LCD HDTV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
Note: Extreme care should always be used when removing
without tools.
sliding the pedestal stand away from the TV.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Removal of tv stand
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
Sep 06, 2009 | Panasonic TH37PX60 37 in. Plasma...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
64 people viewed this question
Jerry Greenberg
Jerry Greenberg
