Question about Zynga Texas HoldEm Poker
Why all the sudden am I not able to access all level tables? I have over 2 billion in chips an can only get to a few tables under 500/1 mill level.
2 Suggested Answers
djalanonymou
SOURCE: suspension of zynga poker
plis open zunga poker Message Code: CA5
Posted on Nov 20, 2012
Tip
Setting up your milling machine for use
Setting up and aligning your you machine and working-hold fixtures is one of the most important stages in getting ready to start milling. If the piece that you are milling isn't locked in properly the machine can ruin the piece or it could cause injury to the operator should it come free from the vise.
There are a few alignments that you will want to pay attention to and make sure that they are alighted properly. They are, table alignment, head alignment and vise fixture alignment.
The table alignment should be checked every time that the table is being returned to the 0* position. It is a good practice to not trust the graduation marks on the machine when you need to do accurate work. When ever you are working on a project that needs accurate angles.
What you are going to need is a rigid mounting dial indicator mounted on the table. It has to be mounted on the table because you are measuring the angle of the table in relation to the column of the milling machine. This will give you a much more accurate reading for the angle of the table.
On a vertical milling machine with either semi universal or universal heads should be checked before preforming a job that requires accurate alignments. To make sure that the alignment is correct you will need to follow a few steps. First you should clean the table and place a flat parrallel plate on it. Connect the dial indicator to the sprindle and feed the spindle down, with the dials lunger at the operator's right or left side until is ragisters to about 1/4 of the operating range, and get it to zero. Rotate the spindle carefullly one rotation on a universal type head the readings will vary on both of the axes. When you are adjusting the head on a universal milling machine you should adjust it one axis at a time to keep it aligned. When it is aligned make sure that you tighten all the locking bolts.
The last alignment that you should check before beginning your project is the vise and fixture alignment. This is the reference surface, where the piece you are going to be milling will be held. To align it attach the dial indicator to the arbor of a horizontal milling machine or placed in the collet of a vertical milling machine. To align the vise you will want to use the following procedure. Start by cleaning all the parts, making sure that there are no nicks on the surface. Clamp the vise in the what appears to be the correct position. Take the dial indicator and bring it into contact with the part that is going to be aligned. Slowly move with in the operating rance until its at zero. Cross slide the jaw to the full length and make note of the variation in the indicator reading using a soft hammer. When you see that the indicator shows no deviation, tighten the blots and recheck the indicator.
Once everything has been checked you should be all aligned and ready to go.
on Feb 06, 2014 | Tools & Hardware - Others
What is the laser classification of Staples mouse B250?
maybe this will help:
  • Class I laser product means any laser product that does not permit human access during the operation to levels of laser radiation in excess of the accessible emission limits as defined in Table I of 21 CFR Subchapter J Part 1040.10. Class I levels of laser radiation are not considered to be hazardous.
  • Class II laser product means any laser product that permits human access during operation to levels of visible laser radiation in excess of the accessible emission limits contained in Table II-A of 21 CFR Subchapter J Part 1040.10, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table II of 21 CFR Subchapter J Part 1040.10. Class II levels of laser radiation are considered to be a chronic viewing hazard.
  • Class IIIa laser product means any laser product that permits human access during operation to levels of visible laser radiation in excess of the accessible emission limits contained in Table II of 21 CFR Subchapter J Part 1040.10, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-A of 21 CFR Subchapter J Part 1040.10. Class IIIa levels of laser radiation are considered to be, depending upon the irradiance, either an acute intrabeam viewing hazard or chronic viewing hazard, and an acute viewing hazard if viewed directly with optical instruments.
  • Class IIIb laser product means any laser product that permits human access during operation to levels of laser radiation in excess of the accessible emission limits of Table III-A, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-B of 21 CFR Subchapter J Part 1040.10. Class IIIb levels of laser radiation are considered to be an acute hazard to the skin and eyes from direct radiation. Class IIIb laser products may have removable panels that, when displaced, permit access to levels of laser radiation ranging from Class II to Class IV.
  • Class IV laser product means any laser that permits human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-B of 21 CFR Subchapter J Part 1040.10. Class IV levels of laser radiation are considered to be an acute hazard to the skin and eyes from direct and scattered radiation. Class IV laser products may have removable panels that, when displaced, permit access to levels of laser radiation ranging from Class II to Class IV.
  • Jan 29, 2016 | Laser Computers & Internet
    Where can I find a billion digit calculator online?
    You should try to read a bit about significant digits. In scientific and technical calculations only a few digits have any meaning and results are rounded. Get a scientific calculator that displays 10 or more digits and that will be more than enough for your very complex calculations.
    You can use the calculator on your computer. Look under the Accessories submenu in All programs.
    Jan 08, 2013 | Office Equipment & Supplies
    Suspension of zynga poker
    Nov 20, 2012 | Zynga Texas HoldEm Poker
    Water spilled on the table under the macbook. now it doesn't work. I see people wating a few days and it restarted. how nmany days should i wait? help!!!
    Jay, Try placing your MacBook on a bed of un-cooked rice for several days that should pull any moisture out of your lap-top. DO NOT ATTEMPT TO TURN IT ON. If you already have it may too late.
    May 06, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
    How many stars do we have in unnivers
    Based on current estimates, there are between 200 - 400 billion stars in our galaxy (The Milky Way). There are possibly 100 billion galaxies in the Universe. So taking the average of our galaxy, gives approximately 3 x 1024 stars. So about 3 septillion. This has been equated to the same number of grains of sand that are on Earth.
    One source (BBC) stated that there are about 1,000 stars to every grain of sand on Earth!! There are an estimated 100 to 200 billion galaxies.
    So taking a conservative number of 100 billion stars per galaxy gives an approximate total of 10,000,000,000,000,000,000,000 stars. (Which is 10 sextillion)
    The newest estimates gained by the Hubble space telescope places the estimate of 500 billion Galaxies each with about 300 billion stars for each galaxy.
    Apr 13, 2011 | Computers & Internet
    Small bubles appearing under red paint. Local
    your correct, if you wait about a year you will notice rust in those spots
    Jan 28, 2010 | 2005 Nissan Titan
    How to export table in ms access to excel
    yes you can export your access data into excel, follow steps on how to export.
    1. open your access database
    2. open the table data you to export
    3. under table data view click tools menu
    4. select analyze
    5. select ms excel
    6. this will open your seleted access table in excel
    hope this will help you..
    Dec 13, 2008 | Microsoft Access 2002 for PC
    Zynga Texas HoldEm Poker Logo
    56 people viewed this question
    Top Zynga Facebook Apps Experts
     Grubhead
    Grubhead
    Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
