SOURCE: cant put unit back together
You can go to the manufacturers website and download everything you will need. Their tech literature is pretty extensive.
http://www.mrslim.com/customerCare/resources.asp
SOURCE: Patton U2 1887 Fan Won't Run After Cleaning
Do you have the cover back on unit tight has a button that kills the circuit when cover is taken off. Be sure it is on. Get back with me if that isn't it. ken
SOURCE: Older Penguin roof shroud, new style fit?
I just replaced my two 620315.321 shrouds with the newer style without any problems. I went to the Camping World site (and called them) with model no. and they knew what to send me. I also found that they had the best price at $79.00 (member price) with free shipping.
I didnt check your shroud part no.s, but think you will be ok if you do as I did.
If you have any question about installing, you can email me at [email protected]
SOURCE: on my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
SOURCE: airconditioner won't cool room off.
The unit,has it cooled the room before?Check the evaporator coil,the one inside the house,where the filter goes,put your hand on the coils gently,and place it all around and feel if the coil is cold,and is it cold all over,if it is not getting cold,all over the front of the coil,then it most likely needs freon.
