Question about Samsung Televison & Video
My Samsung has red squares on the screen - Samsung Televison & Video
Cheat code central
this is some red faction 2 cheats
Unlock All Cheats
At the cheat screen, enter SQUARE, CIRCLE, TRIANGLE, CIRCLE, SQUARE, X, TRIANGLE, X.
Gibby Explosions
To show gibby explosions, go to the Cheat screen and enter TRIANGLE, CIRCLE, X, SQUARE, TRIANGLE, CIRCLE, X, SQUARE.
Unlimited Ammo
To have unlimited ammo, go to the Cheat screen and enter this code: SQUARE, TRIANGLE, X, CIRCLE, SQUARE, CIRCLE, X, TRIANGLE
Unlimited Grenades
To have unlimited grenades, enter this code at the Cheat screen: CIRCLE, X, CIRCLE, SQUARE, X, CIRCLE, X, CIRCLE.
Super Health
To get Super Health, enter this code at the Cheats screen: X, X, SQUARE, TRIANGLE, SQUARE, TRIANGLE, CIRCLE.
Dec 18, 2013 | Sony PlayStation 2 (PS2) Console
Touch screen is frozen but the buttons on the key pad and talk and off button work. ive turned it off and on but still frozen. i have a samsung impression a 877
take out the battery. under the batter there should be a small white square (or circle) if you cant see one but there is a red one the handset may have moisture damage.
Jan 14, 2011 | Samsung SGH-A877 Impression Cell Phone
My google screen is to far right I cannot move it fully to the left
In the top right hand corner there is an X in red and next to it is a square with another square behind it. Click on the square and that will restore your full screen.
Nov 05, 2010 | Computers & Internet
Samsung A737 water damage..??
the little square that you are referring to is a liquid damage indicator, it will change it's color if the phone is exposed to any kind of liquid or moisture.
Jun 27, 2009 | Samsung SGH-a737 Cellular Phone
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Blue and red squares over my image
A histogram is a graphic representation of the distribution of brightness values in an image. The C-5500 has two histograms. One displays a real-time graph on the LCD screen as you compose your images and during the Quick View of images after they are shot. The DIRECT histogram displays potentially over and under-exposed areas in the image with a grid of squares—red for over-exposure and blue for under-exposure. You can set the histogram to OFF to prevent the histogram from appearing.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Televison & Video Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
