Question about Garden
What is the trick to starting a new riding mower?
It was bought three years ago and never started. It never had gas in it and we put on a new battery. pleny of oil. So what is the trick. It does turn over
  • 575 Answers
Make sure it has gas and at the bottom of the tank open the valve that allows gas flow. By the steering wheel there should also be a choke. Make sure it is closed for startup.
Posted on Apr 17, 2015
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
MTD RANCH KING RIDING MOWER TURN KEY AND JUST CLICKING NOISE. DID PUT NEW SOLENOID TWO YEAR AGO. OLDER MODEL RANCH KING.RAN AT END OF GRASS YEAR BUT NOW JUST CLICKS ????
make sure all terminals are clean & tight on all + & - from battry to starter check that terminals are snug on ends of cables if still clicks put screw driver across selenoid with switch on from hot cable to hot cable both should be red you mite get a little spark thats ok should start if so cut off & try w/key sometimes switch or regulator will cause same problem sometimes they will keep starting with key
Feb 12, 2015 | Mtd Garden
New husqvarna riding mower hard to start
get it adjusted and repaired under warranty
don't put up with it as it will get worse not better then be out of warranty
Jan 19, 2018 | Garden
Has spark, has gas, cranks over and trys to start but will not
hello david,Has spark, fuel trys to start,could be bad fuel as old,water in fuel or tank,gas container with debris,crankcase over full on oil and gas,bad coil,bad plugs,low compression,blown head gasket,valves adjustment if ohv, these are the things i would check if i had it here in the shop,hope this helps,
Feb 19, 2012 | Garden
I have a Troy Bilt 175 HP 500cc 7 speed riding mower. I just bought a new battery, and it still won't crank. It'll turn over like it wants to, but nothing. I put new gas with the old gas from last season...
If you didn't put fuel stabilizer in gas before letting the mower setup all winter, your gas has gunked up your carb.
You can verify this by removing the air filter and spraying starter fluid in the carb. If it cranks with the starter fluid, the carb is dirty.
Pull the carb and clean it out
Dec 08, 2017 | Troy Bilt 175HP Manual 42" Riding Mower
I bought a john deere riding mower less than a year ago. i used it last season without any problems. I think the last time i used it, was in august 2010. winter came about, the grass wasn't growing, so...
First, I've had a motorcycle for almost 50 years and have never drained the gas. At one point it was not used for 3 years. It started, I added gas and it ran fine.
Second, next time you are running the machine and it begins to stall, immediately loosen the gas cap. If it starts to run good again, drill out the air vents on the cap.
Gary
Mar 09, 2011 | Garden
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
