Question about Garden
I need the gas lines that go in the fuel tank
  • 575 Answers
Remove the old lines and get them matched up at a parts store
Posted on Apr 17, 2015
Need to know what 3 lines from fuel tank go
The pump line, or feed line, goes to the fuel filter and then to the engine's fuel rail. A return line leaves the fuel rail and sends gas back to the tank. Usually, the feed line is slightly larger than the return line, not always.
The third line is a vent line for emission controls-routing gas fumes from the tank to the charcoal canister, where it is stored and later sent to the engine to be burned.
May 31, 2015 | Cars & Trucks
How do you fix the fuel line that has come out of the gas tank on a weedeater edger 550?
The connector in the tank is the fuel filter. Yes this needs to be reconnected for the unit to operate. I suggest changing the fuel lines to new lines.
Jul 22, 2014 | Weedeater 19 in 25cc Gas Hedge Trimmer
Why is gas shooting out of gas cap?
you have 2 options
1--- put the fuel return line into the tank you are using
2--- install a balance line between tank 1 and tank 2 so that the fuel back to tank1 is allowed to balance back into tank 2
properly set up the tanks should be connected so that the fuel gauge reads the total fuel in the tanks and there is a need for only one fuel pump
Nov 09, 2017 | 1990 Ford F150
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Please take time to rate me
Sep 24, 2011 | Garden
Need 2 know how 2 remove gas tank so i can replace fuel pump
TO REMOVE FUEL TANK FIRST YOU NEED TO MAKE SURE FUEL SYSTEM BEEN DEPRESSURIZE. YOU CAN REMOVE FUEL PUMP RELAY LET CAR RUN UNTIL DIES LACK OF GAS. THEN CRANK ENGINE OVER FEW TIMES MAKE SURE ALL GAS OUT OF FUEL LINES. THEN REMOVE FUEL CAP THEN DRAIN FUEL TANK.YOU CAN BUY A SIPHON AT ANY AUTO PARTS STORES, DONT SIPHON GAS WITH MOUTH CAN BE VERY FATAL.ONCE FUEL OUT OF TANK. SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS, MAKE SURE VECHICLE SITTING ON LEVEL SOLID GROUND. LOOK UNDERNEATH VECHICLE REMOVE FUEL FILTER DISCONNECT FUEL PUMP ELECTRICAL WIRE CONNECTOR, THEN REMOVE EVAP CANISTER, VENT SOLENOID, AND VAPOR LINES DISCONNECT FUEL LINES, THEN REMOVE THE LOWER FILLERHOSE GOING INTO FUEL TANK. LOOK AROUND TANK YOU PROBABLY HAVE TO REMOVE HEAT SHIELD AROUND GAS TANK AND REMOVE EXHAUST PIPES IF IN THE WAY. GET A LARGE FLOOR JACK AND THE PLACE A PIECE WOOD ON FLOOR JACK SADDLE.THEN RAISE FLOOR JACK JUST ENOUGH SUPPORT FUEL TANK THEN REMOVE FUEL TANK SUPPORT STRAPS THEN SLOWLY LET DOWN THE FUEL TANK. TO FINISH DISCONNECTING FUEL LINES AND REMOVING FUEL PUMP. BE SURE AFTER YOU DEPRESSURIZE FUEL SYSTEM TURN OFF RADIO AND REMOVE THE NEGATIVE BATTERY CABLE.
Aug 04, 2011 | Chevrolet Cavalier Cars & Trucks
Need to replace all gas lines
  1. Empty the fuel tank on the chainsaw of any remaining fuel. Pull the cap from the tank and turn the unit upside down. Drain the fuel into an approved fuel container. If the fuel is old (more than about a year) dispose of it according to local regulations for hazardous materials. (It can be kept longer by adding a fuel stabilizer.)
  2. Pull the fuel line where it attaches to the carburetor using the end of the needle-nose pliers. The old fuel line may take some force to pull free from the metal tube.
  3. Push on the fuel line to feed it into the fuel tank. Hold the chain saw upside down. Shake the unit to get the fuel filter into the opening of the tank. Pull the filter free of the tank. Feed the remaining fuel line through the access hole at the bottom of the tank. Dispose of the filter and old fuel line in accordance with disposal regulations.
  4. Feed one end of the new fuel line into and through the bottom access hole of the fuel tank. Push approximately 6 to 8 inches into the tank. You can pull back any excess line later. Grab the end of the plastic line with the needle-nose pliers. Bring the line through the gas tank fill opening.
  5. Attach the new filter to the end of the new fuel line. Feed the filter back into the fuel tank. Pull any excess line from the tank. You will want approximately 3 to 4 inches of fuel line inside the tank.
  6. Route the new fuel line to the carburetor. Cut the line to length with the cutters on the needle-nose pliers. Attach the line to the metal tube.
  7. Fill the fuel tank with fresh gas-oil fuel for 2-stroke engines and start the chainsaw. It may take a few pulls to prime the new line with fuel.
  8. Some models come with a priming bulb. Make sure you press the priming bulb three to four times before trying to start. This will prime the gas lines and remove any excess air trapped in the lines.
Nov 15, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Have a weedeater gt1 15 trimmer how do u get the gas tank apart to repair the gas tubing
You will not need to remove the gas tank or take the gas tank apart. Follow these instructions:
1. Disconnect the fuel line from the carburetor. You may need to cut the line pull it off.
2. Push the fuel line back through the gas tank. At the end of the fuel line is the fuel filter/weight that should be moving around within the gas tank.
3. You should be able to pull the filter/weight out of the fuel tank through the neck using a needle nose pliers. Insure the fuel filter is cleaned out before you re-assemble.
Note: The fuel line that you use as a replacement must be the same diameter of the fuel line you are removing. If you cannot find the fuel line at your local mower shop, try Lowes Hardware as they do stock it in the lawnmower section.
To reassemble: Take about 7 inches of correct fuel line and cut a 45 degree angle cut at one end. That end is threaded back through the tank through the small hole. Push as far as you can and then reach in and pull it to the neck. Cut the straight, attach the filter/weight and pull the line back through.
Sep 28, 2010 | Poulan Garden
Fuel Lines leak where they pass through opening into tank
i had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Jun 03, 2009 | Homelite Mighty Lite Lawn Trimmer
No gas to manifold,car will start adding gas to throttle body
yes gas should be coming out of the fuel line at the motor. if not the pump is bad. you will need to drop the tank to get to it as it is in the tank
Dec 01, 2008 | 1993 Pontiac Bonneville
I've got bad gas and need to know the easiest way to drain the tank or otherwise fix the problem.
The tank will have to be removed from the vehicle and completely dried out.Gas tanks no longer have drain plugs as they did 50 years ago.Remove the fuel pump from the top of the tank,and thoroughly clean the tank with brake cleaner and compressed air and let air dry for awhile.The fuel pump and filter will need to be replaced with new,and after all the reinstallation,the fuel line must be disconnected at the engine,and the line flushed with new,clean gasoline as well as the return fuel line.Spark plugs will have to be replaced also.
Aug 12, 2008 | 2003 Toyota Matrix
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
