Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 plus, in 1-VAR STATS the list: will not insert comma between lists
  • 575 Answers
1 var means only one: where would it put the comma?
Posted on Apr 17, 2015
What does Dim Mismatch on TI-83 mean?
You have a dimension mismatch if (for example) you are doing 2-var stats and the two lists do not have the same length. You can also have mismatch with matrices.
May 08, 2014 | Texas Instruments TI-84 Plus Calculator
How do i find grouped data in L1 and L2 on ti 82
I am not sure I understand but if it the same problem as in your other posted question, here is what I wrote.
Are the data in L1 and l2 in any way related? If they are (being x-values and y-values of some data set) then you need to do regression analysis (2-var stats)
If they are not related (connected) you can calculate the mean of each group separately.
Do 1-var stat by specifying the L1 list first (may be the default), get your average of the values in L1. Then you can do 1-var stat on the data in L2 by specifying the list L2 on the command line.
1-var L2 ENTER
Note: What I am describing here is valid for the TI 83 Plus/TI84 Plus, but I suspect the steps are similar to the TI 82.
Oct 08, 2013 | Texas Instruments TI-82 Calculator
Error stat
1-var L2 ENTER
My TI-84 plus silver edition doesnt allow me to use the comma when using the 1-Var Stats button.. I can't use more then one list and I need the mean of both lists
Pay attention to the name: 1-var statistics mean you have ONLY one list of data. So you cannot use two. However if some data values are repeated you may choose to create a FREQuency list. So at most you have two list, one for the data values and the second for their frequency.
When you use the 1-var stat, specify the list that holds the data value (Xlist) and one the FREQ line specify the list that has the frequency
If your data values are in L1 and L2 or any pair of lists, then you should do 2-var stats. You will get the stats of both lists, you can also perform regressions, etc.
Apr 09, 2012 | Texas Instruments Office Equipment &...
Multiple operations in single command on new TI84
Run SetUpEditor to restore the list names L1, to L6
100->dim(L1) to set the dimension of L1 to 100
100->dim(L2) to set the dimension of L2 to 100.
Since you are going to store the random numbers in L1, you should use L2 as the FreqList. All elements of L2 should be 1. When you create it all its elements are 0. One way to fill it with 1's is 10 run the command
L2+1>L2; Add 1 to each number and store the results in L2 (overwrite the 0 values)
Perform a blank run of 1-var Stats to get the chance to set the default lists.
1-var Stats L1, L2 ENTER
Type in your command
randNorm(64.5,2.5,100) STO> L1:1-var Stats L1, L2 ENTER.
Use the Catalog to type in the 1-var Stats commnad so that you can type in the Lists L1 and L2 without opening the 1-var Stats configuration screen.
Do what you have to do with the statistics you generated.
To rerun the two commands again, press [2nd][ MODE] to (QUIT)
or press the sequence [2nd][ENTER] to have the last (ENTRY) echo on the main screen. Press ENTER to run again
Hoe it helps.
Jan 13, 2012 | Texas Instruments TI-84 Plus Calculator
When I go into the 1 Var-Stats menu, I need to type in L1 and L2 but my comma button will not work. It will only let me type in one list at a time, and if I put two lists in without a comma it says error....
If you are performing 1-variable statistical calculations, that presupposes you have one set of data only. Technically all you need is ONE LIST where the data is stored (ex. L1) . However if you have some data elements that are repeteated, you may choose to create a second list where you enter r the frequency (L2 or other). Both lists must have the same dimension (length).
When you bring up the 1-var calculation menu , the list of data elements is specified on one line (Xlist) and the fequency List is specified on the menu line Frequency. Thus there is no need to enter two lists on the Xlist line.
Oct 16, 2011 | Texas Instruments TI-84 Plus Calculator
I am curently taking Statistics and when I hit "stat" then enter information into the L1, L2 , L3 area etc then I go to stat again and press calc and choose option 1 then in the list area I need...
I have followed your description and entered bogus data in Lists L1, L2, and L3.
I hit STAT then CALC then Option 1, which is 1-Var Stats. In this context you have only one set of data. If the data set contains many repeated values you can enter the frequency for each (repeated) data item in List L2, inserting 1 if an item is not repeated.
Thus when you do 1-Var Statistics you have at most two Lists (L1 contains the data values, and L2 their frequencies).
If you press the 1-Var Stats calculation option, the calculator takes L1 as the default data list so you see List:L1 and the ALPHA cursor blinking
On the secoond line you see Frequency: and nothing else on the line.
On the third line you have Calculate.
If Your data is not in L1, you can change that by pressing the [2nd][2] (L2), or [2nd][3] (L3). Only one list is specified there, so no need for the comma to separate. (you are doing 1-var Stat).
If your frequency data is in L2 you must specify it on the line Frequency. However, since the ALPHA keyboard is activated you must deactivate it first by pressing the ALPHA key. After that press [2nd][2] to select L2 or [2nd][3] to specify L3
If there is no frequency list, leave the Line frequency empty.
Aug 25, 2011 | Texas Instruments TI-84 Plus Silver...
How do I compute population standard deviation on the TI 84 plus?
Put the data into a list using whatever scheme you prefer. Press STAT right-arrow to bring up the STAT CALC menu. Select "1-Var Stats" and specify the list containing the data. You'll get a screen showing the various statistical values. The population standard deviation is designated by a lowercase sigma.
Jun 01, 2011 | Texas Instruments TI-84 Plus Calculator
When I entered my data in L2 because in L1 I don't know what happened is not on the screen then I press STAT and select CALC, then select 1- Var Stats and press enter I should be able to see the mean,...
When you select 1-Var Stats, specify L2. If you don't specify a list, the calculator will assume L1.
You can recreate L1 by pressing
2ND [{] 1 STO 2ND [L1]
{ is on the ( key.
L1 is on the 1 key.
Jan 27, 2011 | Texas Instruments TI-84 Plus Calculator
When I type a list of numbers into L1 and then hit Stat, calc, 1-var stats L1. i get invalid dim
  1. Press [STAT][5:SetUpEditor][ENTER].
  2. Press [STAT][1:Edit..]
  3. Enter your data in L1.
  4. Press [STAT][CALC][1:1-Var Stats].
  5. Command echoes on main screen.
  6. If ONLY one list contains data, it must be L1.
  7. When you do not specify the list in the command line it will take L1 by default.
  8. If L1 is empty and the data is in L2, or another but L1, the name of list must be specified.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
385 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
