Question about Dryers
How do i fix or repair tigger?? - Dryers
  • Paul Bade Apr 17, 2015
    Hi sherman bellegarde, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is Tigger a plush toy with an electronic sound device inside?
  • 744 Answers
Tigger?
Posted on Apr 17, 2015
How to get your tigger from sticking on my poulan predator chaINSAW
Trun over saw look at BAC handle small screw should b there
May 23, 2014 | Poulan PP4218AV 18" Chain Saw
My bostitch N88RH is not firing nails
May occur when headvalve or driver is stuck (will usually make a pop or click when tigger is depressed), or tigger valve has failed or safety not actually touching trigger firing pin. Easy test, remove nails, remove trigger by pushing out 3mm roll pin or bolt to expose the firing pin. Pull back nail feeder and place the nose against piece of wood ~ depress trigger with very quick motion with finger. If it fires, reinstall trigger and adjust safety foot so that the firing pin is pushed all the way in. If does not fire, replace trigger valve (usually tva6) or remove trigger valve and replace the 3 orings on the inner plunger. If you hear a pop or click when you do test above, remove head and lube the headvalve orings with white grease or silicone paste.
Nov 17, 2011 | Stanley Bostitch N88rh Framing Nailer...
I have a n80sb have bought two tiggers and put in it av11 they both leak from the outside of the tigger what do i do
forget the out side trigger levers,you need the trigger valve assembly,its inexpensive go to your nearest bostich dealer
Dec 28, 2010 | Stanley Bostitch F21PL Nailer
E tigger keeps firing without pulling th trigger
Put a piece of wood behind the trigger. That should stop it, or simply remove the ammo.
Mar 27, 2010 | Tippmann 98 Custom Act Paintball Gun
I have a tumble time tigger and can't figure out how to change the batteries - any ideas?
I believe the battery compartment is in the foot of tigger
Jan 10, 2009 | Toys
Hard Floor vacuum, solution doesn't dispense
You might check your owner manual to make sure that you switched it over for wet. If still no luck, and you said it was new, you have a years warranty, take it to a warranty repair shop.
Mar 26, 2008 | Vacuums
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
