Question about Measuring Tools & Sensors
Why my outside transmiter don't work - Measuring Tools & Sensors
  • 20 Answers
Could you provide us with the model number of your weather station?
Posted on Apr 20, 2015
  • 16,195 Answers
The first thing to do is bring it in close to the base and see if it works. Then use the process to reset it and then change the battery. All those things could impact the operation of it.
Posted on Apr 17, 2015
Rc sensor outside will not transmit 4-ld3091-t
Try physically taking your inside unit outside, and replacing the inside unit batteries as close as possible near the outside unit. Once the transmitter has found the signal, it should lock on and continue to work. Good luck.
Dec 08, 2014 | Measuring Tools & Sensors
Kenwood tm-281a transmitting but no one can hear me.
How is your antenna? Do you have another 2 M radio? Try feeding a dummy load and listening on another radio nearby. Look at the display when you transmit. Does it show the right frequency? If you have the offset wrong and it is taking you outside the band, it will likely not transmit. Do you have a power meter? Does the rig's current drain go up when you try to transmit? (Does the power supply keep the voltage up when you try to transmit?) Supply voltage dropping will cause the rig to NOT actually transmit.
Nov 14, 2014 | Radio Communications
Ftl2011 nao transmite
More information is needed to help you; On which frequency are you trying to transmit? The radio has its band limits set by regulations of different countries. If you're trying to transmit on a frequency that's outside the limits of what the radio is setup for, it won't transmit.
Sep 08, 2013 | Vertex Radio Communications
Meter don't work
Hook radio to a dummy load with a watt meter in line---if no actual power being transmitted radio will not go to cal or show transmit power.
May 19, 2012 | Cobra 29 LTD CB Radio
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
Not transmitting
  • Scanners don't transmit, they receive only. That the way they are built. Not only do they not transmit but one would get in some MAJOR hot water if they were caught transmitting on police frequencies at all.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 06, 2011 | Radio Shack Pro-97 Handheld Scanner
How do I cancel a transmitted design. The needle
Turn the machine off and remove the hoop. Reboot the program and turn the machine back on.
Mar 11, 2010 | Singer CE-200 Quantum Futura Computerized...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Measuring Tools & Sensors Logo
518 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
