Question about Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor
THE BLADE DOES NOT ENGAGE WHEN I PULL OUT THE KNOB THAT IS SUPPOSE TO ENGAGE THE MOWER BLADE
    Sergeant:
  • Allis Chalmers Expert
  • 187 Answers
"I have an Electric Clutch and my Blades will not engage when I operate the PTO switch."
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Is the deck belt intact?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared?
  • When you pull the PTO switch does the clutch make a "click"?
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. Do not confuse this click with the clutch click.
Leave the Key in the Run position, cycle your PTO Switch on and off. You will hear a click. This click will be twice as loud as the fuel switch click. This louder click is the Clutch engaging. If you do not hear this click, the PTO switch may be bad or the Clutch may be bad. This is assuming your battery is good and fully charged and that your Key Switch is functioning correctly.
PTO Clutch will Not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Posted on Apr 18, 2015
Pulled the knob to engage blade but blade would not engage.motor stops
possible bent damaged seized shaft, look under deck for excess debris, rope, damaged blades
Jan 28, 2016 | Husqvarna "RZ4621 46"" Briggs And Stratton...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
How do i fix my zero turn mower, will start,if blade knob is turned on kills engine, will not move with sticks when running , key will not kill engine.
this sure sounds as if you have a seat switch issue , this is a safety device to make sure theres an operator that weights more than 115 lbs in seat , the blade engauge problem and non movement tells me this
May 06, 2015 | Toro TimeCutter SS5000 zero turn mower
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
Cub cadet lt 1018 blade will not engage when i pull knob up
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blades will not engage when you pull up on the button
When you pull switch to turn on blades do you here a click sound ? If so clutch is most likely ok,did you check your belt to make sure its ok ?Seat switch is just a saftey feature it cuts all power to the clutch so thats why blades turn off,thats why I asked you if you here a click when pulling switch that will tell you if there is power to switch.there is also most likely a fuse in the line that goes from the clutch switch to clutch.
May 09, 2009 | Garden
Mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
Nov 22, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor Logo
199 people viewed this question
Top Allis Chalmers Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Allis Chalmers Garden Expert? Answer questions, earn points and help others
