Question about Home
How to reassemble after cleaning? - Home
When I try to start my 1989 cadillac eldorado why does my dash go out and car won't start?
The battery is dead and/or the connections on the battery posts are corroded. Remove the battery post connections and clean the contact surfaces with sand paper and reassemble. Charge the battery while you have it disconnected and after cleaning and reassembly it should work fine. Batteries do get old so yours may need to be replaced if it will not charge.
May 14, 2014 | 1988 Cadillac Eldorado
Will not start
poss.if taken apart and reassembled ,you did not reassemble properly causing something to catch,or your switch is dirty with debree,clean contact on switch. does the motor have a burnt smell to it if so then toss it and get another.
Oct 13, 2010 | KitchenAid Blenders
Hi, i have a LB290 canon printer & i want know that how i can refill it? & i can use HP toners for refill the canons cartridgs? tank u
try this way
it is much more easy
http://www.youtube.com/watch?v=iMiTopIVMxM
hope i help you
please vote me
Mar 06, 2010 | Canon LASER SHOT LBP-2900 Printer
I have compression, spark, and gas/oil mix. engine not starting.
When cleaning the carb., use a De tek Brush,(used for cleaning between teeth), to clean the small portals. The smallest particles can keep it from running. More than likely though, It will be the small screen in carb. It can become clogged up to the point where you can't even see daylight through it; not good!
Jim
Jun 04, 2009 | Honda Hmantis Mantis Garden Tiller with...
I perfomed some cleaning to my dell pc, on reassembling, the pc
Hello orwason,
This has haapened to me to, very frustrating. The problem is something loose inside. When you did the cleaning something came unseated, a pci card or an ide connector. Go through and make sure all connectors are snug in their respective slots. Also, make sure you unplug the power cord before touching the inside. Let me know how it turns out for you.
Nov 21, 2008 | Dell Precision 530 Minitower 2.4Ghz...
Screen cleaning
of course). There is nothing mentioned of this in the service manual. The workshop manual says 'clean' when you are reassembling the engine after a complete teardown. I don't do that very often . There's no risk things fall apart when loosing the cover?Yes just undo the plug on the side near gear selector. Be careful with screen as it is plastic and has o-rings to seal it. Clean with degreaser works best I feel. Reassemble putting screen fully in first then carefully screwing plug back in.,
Nov 10, 2008 | 2006 Gas Gas SM 450 FSE
Screen cleaning
Nov 10, 2008 | 2002 Gas Gas EC 400 FSE Supermotard
Sony vaio pcg 6F1L
Do you mean clean inside the LCD itself?? did it get water in it??
Not a fun thing to take apart an LCD and hard to reassemble as well. If you break the circuit boards while taking it apart you have to buy a new LCD.
Here is a good example of what replacing a backlight involves including disassembly pictures:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Dec 23, 2007 | Computers & Internet
Home Logo
146 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
