Question about Hotpoint WMA40 Front Load Washer
Drum does not turn
Hi, I just made a wash and after it finished the drum does not turn. I tried to turn it by hand but it is like stuck or dislocated (maybe because it was quite full during the previous wash). Any ideas if and how I can fix it myself?
    New Friend:
  • 15 Answers
Check belt, bearings and that the motor spins freely .
Posted on Apr 17, 2015
Testimonial: "any suggestion how? I have never dealt with sth similar"
    Genius:
  • Hotpoint Master
  • 1,585 Answers
Check bearings and belt
I have azanussi zwf1437w washing machine. The drum has become stuck and won't turn and can't be turned by hand. There are no socks etc stuck between the inner and outer drum that I can see.
Well, I hate to tell you, but the drum will have to be looked at and that means opening the machine up. It probably dislodged from its mounts from excess vibration caused by unbalanced loads in the drum.
Jan 15, 2013 | Zanussi Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Washing machine drum wont spin or turn by hand
If you cannot turn the drum by hand, then the main drum bearings have probably seized up, or there is something stuck between the inner and outer drum.
Nov 16, 2010 | Zanussi Washing Machines
Drum is stuck and does not move after a noiny spin. pls advice.thanks
Sounds like possibly the main drum bearings have seized.
To check, remove the rear panel of washer, remove the drum belt, and try to turn the drum by hand, if it is noisy or rumbling, or not turning at all, then likely the the drum bearings have seized.
This is a major repair, and could be expensive!!!
Mar 17, 2010 | Indesit W 123 Front Load Washer
LG WD-8050FH - Stuck nuts!
Tap a hammer on the screwdriver as you turn - not too hard but as not to damage anything but firm enough to loosen thread
May 06, 2017 | LG Washing Machines
Washing machine has started to make noise. What could be the issue.
could be coupler or bearings on the bottom of the agitator and tub
Jul 09, 2009 | Maytag MER5775Q Electric Kitchen Range
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
TUB WON'T MOVE , EVEN BY HAND
TAKE THE BACK COVER OFF, EITHER THE MOTOR IS SEIZED UP OR THERE ARE SOME CLOTHES STUCK BEHIND THE DRUM
May 29, 2009 | Washing Machines
Drum sticking
take the heater out it will be stuck round that or wraped round the front of the drum u may be able to get @ it if not im afraid u will have to split the drum to get it out if u r not an enginer i would not attempt it good luck
Sep 15, 2006 | Tricity Bendix AW1000W Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
