Question about Sanyo Televison & Video
I have my Sanyo flatscreen that perodically shows a black bar with numbers and letters in the middle and/or bottom of the screen. The kicker is that it only pops up on 1 specific channel.
    Top Expert:
  • Sanyo Master
  • 51,186 Answers
SOURCE: Black square box pops up in the middle of tv screen.
It is most likely related to the Closed Captioning option on your TV. Go into settings and make sure that CC is turned off, or make sure it's set to CC1. What you are probably seeing is the "text" option included in the CC options.
Posted on Feb 15, 2009
rlamkin
  • 44 Answers
SOURCE: black bar down middle of screen
these cables are machine installed on the panel itself, not user fixable. however, the cables are mounted to a circuit board at bottom of the screen. to reach they you need to remove nearly all the support structure and boards at the bottom of the panel. there are a number of sensitive parts under there and they have black 'licourus' on the chips to dissipate heat. good luck.
Posted on May 05, 2009
  • 15 Answers
SOURCE: big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Posted on Aug 14, 2009
  • 7 Answers
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
Posted on Dec 31, 2009
james tv man
  • 91 Answers
SOURCE: there is weird letters popping up on the screen
Ok..........un plug the set and your cable or sat reciever.........plug back in to reboot both........be sure your set up shows captions and text "off"
Next step if this does not solve is to play a dvd and see if ok. this will separate the tv from your cable or sat reciever. If still continues your set may have corrupted data in the eeprom and need main board. Try the ez stuff first!!
Posted on Jun 04, 2010
Black bar with letters and numbers pop up in the middle of the screen.
Did you try pressing the 'EXIT' button on the remote?
May 03, 2015 | Televison & Video
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
I have a IBM T210 flatscreen, 20.8 inch. I have done everything possible with the resolution inside windows. I have also gone through every setting in the menu's of the monitor. The monitor is working...
Can u change the screen from 16:9 ratio to 4:3 or regular if it's available in the menu? Black bar at top and bottom generally signifies widescreen...16:9
Feb 03, 2018 | IBM T210 (Pearl White) Monitor
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Apr 12, 2010 | Dell 1702FP UltraSharp 17" TFT LCD...
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Black bar down middle of screen
May 05, 2009 | LG 42PG20 42 in. Plasma HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
57 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
