Question about In-Sink-Erator InSinkErator Badger-1 1/3 HP Garbage Disposal
Not starting. checked the circuit braker
Ran fine one day the next flipped the switch, does not turn on. Checked circut breaker. Fine. Next steps?
  • musa_vadnais Apr 17, 2015
    It is an In-sink-erator disposal, not septic tank.
My 2015 viking spa circuit breaker keeps kicking off when i flip the switch, what do I need to do?
There is a capacitor on or near the motor that is most likely bad or the centrifugal switch inside the motor is intermittent. Service tech is needed
Sep 14, 2017 | Heating & Cooling
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
May 24, 2014 | 2004 Honda VT 750 Shadow Aero
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Aug 17, 2011 | Crosley Dryers
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
I have 137,000 miles on a 3 cyl. 1998 metro, It stopped running going down the expressway, there's no spark and the cam stills turns when cranking over. Two days before I put a new o-2 senor on and it...
I would check to see if there is any spark coming from the coil.If there is no spark there I would start looking at the fuses.Check all the fuses sometimes they run things like that through other circuts as well as it's own circut, so a fuse labled ECMB,IGN,ECMA.... should be checked also.
Jan 30, 2010 | 1998 Chevrolet Metro
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
In-Sink-Erator InSinkErator Badger-1 1/3 HP Garbage Disposal Logo
386 people viewed this question
Top In-Sink-Erator Plumbing Experts
Donni Steen
Tom Chichester
Are you an In-Sink-Erator Plumbing Expert? Answer questions, earn points and help others
