Question about Ryobi Drills
Ryobi Impact wrench won't release bit
Won't release bit from wrench
  • 24 Answers
I would spray a little bit of WD-40 while pointing the bit up towards the sky. The fit is very tight and any rust can jam the bit. When the tool is stored properly to prevent rust and used regularly this won't happen. If I'm going to use bit with rust I wire brush it first and then put a drop of oil on it.
Posted on Jan 04, 2016
4 Suggested Answers
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Posted on Apr 11, 2009
  • 142 Answers
SOURCE: I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Posted on Feb 01, 2012
Testimonial: "Problem solved!"
  • 1162 Answers
SOURCE: how do i put in a drill bit in ryobi 500w impact driver
hold the black part of the chuck with one hand and turn on drill with a bump and the chuck will open. then insert bit. if you feel chuck not open reverse the switch and it will open.
Posted on Feb 01, 2015
I have a bit that will not release from the chuck
Tap the end of the bit a couple of times with a light hammer. This will often shift it.
Mar 06, 2016 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
Drill bit stuck in ryobi impact drill
Put the bit in a vise and try to turn the drill to release the bit. You will need to put a wrench on the area of the drill that's holding the bit and do the turning by the wrench.
Jan 12, 2015 | Ryobi Drills
How do you insert a drill bit?
Grasp the ring at the nose of the drill. It has knurling around it. Pull it forwards and insert an impact rated driver bit or hex shank drillbit. Let the bit slide into the recess until it bottoms out. Release the knurled ring. You should hear the little keeper bearings spring back into place. Your toolbit should now be captive so you can go to work.
Apr 28, 2014 | Ryobi Impact Driver Kit: 18-Volt ONE...
How do you Insert a Ryobi One+ impact driver drill bit?
don't think there is much to it. See page 4 in this manual
http://www.ryobi.com.au/Ryobi/files/e0/e029b72d-32ec-4e92-a555-2a3caac4fa92.pdf
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
Ryobi 18-Volt Impact Wrench P260 stop during use
Well I was having the same problem and I found out that the p108 and p109 cut power when to much of the battery power is being used, kind of dumb just to say the new batteries last 4x longer( its because u can't use all the torque of the impact). Fortunately I've found out that the older batteries don't cut power such as the p104 p103 and the black ryobi batteries without the gauge indicator work the 1/2 " impact without cutting power
Mar 19, 2013 | Ryobi 18-Volt Impact Wrench P260
Someone stuck a conventional driver bit into the impact driver and it is stuck tight.
VERY GENTLY. . . . use a flat tip screw driver to try to push the collar forward so that it will release the bit. You may need to gently hold the handle of the impacter in a table vice or something like that to steady the tool, then push forward on the collar with a screwdriver and use a pair of pliers to pull outward on the bit at the same time.
Or instead of a screwdriver try vicegrips that are adjusted loose enough to just lock but not squeeze when closed. Pliers that grip too tightly may bend the collar and keep it from being able to slide forward to release bits.
Dec 03, 2009 | Ryobi 18v Variable Speed Impact Driver...
Apr 10, 2009 | Ryobi 18v Variable Speed Impact Driver...
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Hitachi Quick Release Drill problem
put a box end wrench 7/16 or a 3/8 over the bit. put the bit in a vise. Lightly tap the wrench with a hammer while holding the relase sleeve back. usually need 2 people. 1 to hold the drill and the sleeve and 1 to hold the wrench and hammer. try a little tranny fluid or wd40 in the chuck. don't use the painted bits. use onle the chrome ones
Sep 30, 2008 | Drills
Drills Logo
319 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
